Old 06-10-2021, 11:05 AM #46
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Made a quick skid plate. 1 hole will have to be drilled to get a bolt in and 2 holes for drain plugs. Still needs some bracing, but ran out of time. Ive been sitting on this piece of plate for about 4 years. I didnt even have to trim the shape just transfered to cardboard and went from there, it was just about a perfect fit. I would consider this version 1. Well see how it holds up and re make if needed..
The steel is from an old under ground oil tank dating back to the 1920s.
Made some slices, bent it up in the press and welded it back together.
Paints drying. On truck pics soon.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 03:00 PM #47
MickyC's Avatar
MickyC MickyC is offline
MickyC is on a distinguished road
MickyC's Avatar
That's not 'skid plate', it's tank armour.
Then again, that is what we need here in Vermont...
MickyC is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 08:11 AM #48
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Hah! Thanks! well see how it holds up! Swing by if youre every in Northfield.
IG: rattlewagon
Old 06-13-2021, 02:39 PM #49
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
And on the truck
3 years later, its back on a trailer headed wheeling
IG: rattlewagon
Old 06-14-2021, 07:46 AM #50
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
4runner did great all weekend. Needs better brakes, currently has the stock 84 rotors with v6 calipers, so well be addressing that next, and hopefully doing a cage soon.
Jungle Summer Bash 21, Trail 1 - YouTube
IG: rattlewagon
Old 09-07-2021, 07:49 AM #51
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Been 3 trips out so far with the runner and the only trail fix we had to do was a loose battery terminal. Still needs other little things like pinion seals and an exhaust. Hopefully starting on a cage here soon.
Got some used unknown seats mounted. Some one had started fitting them a toyota, so we really only had to make 1 mount.
New IFS calipers and FJ60 rotors to help with braking. I believe it has a 1"master and newer booster already on it. The truck stops much better now but still has a very "hard" pedal.
The chair hes sitting in is the original drivers seat with some casters on it.
IG: rattlewagon
Old 09-09-2021, 03:17 PM #52
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
i still want the rims!
new seats look good!
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 07:26 AM #53
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Picked up a few sticks of 1.75 .120 wall ERW to start on a cage.
IG: rattlewagon
Old 09-27-2021, 09:12 AM #54
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Not doing too bad for 3 guys who have never really bent tube before.
IG: rattlewagon
Old 09-27-2021, 10:49 AM #55
lledwod lledwod is offline
lledwod is on a distinguished road
Great work! Nice to see them livin' on!
lledwod is offline   Reply With QuoteReply With Quote
Old 09-29-2021, 07:11 AM #56
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Thank you! Hopefully this one lives for a long time.
Little more progress on the window bars. Will do a crows foot on top.
IG: rattlewagon
Old 09-30-2021, 07:29 AM #57
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
"fastback"
This will get one more horizontal bar
We did this without the cap around, but it "should" fit back on. Goal is to have it read for next Wednesday/thurs evening run.
IG: rattlewagon
Old 10-03-2021, 03:17 PM #58
Dropzone's Avatar
Dropzone's Avatar
you will be able to get the top back on with the 'X' bar?
Notching the cap so it slides all the way in?
@503dropzone on IG
Old 10-04-2021, 08:23 AM #59
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Yeah, it will have to be notched on the top around the X. Small price to pay for the added strength.
IG: rattlewagon
Old 10-07-2021, 08:07 AM #60
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Still needs finishing, but got paint on some of it and took it in the woods..
IG: rattlewagon
cares , fuel , fun , runner , truck
4Runner + T4R.org = bank account danger engineeer 5th gen T4Rs 47 08-14-2017 02:20 AM
Am I in Danger?! corny 3rd gen T4Rs 7 11-22-2014 01:18 PM
Danger Zone! parkay Classic T4Rs 26 03-11-2014 08:18 PM
Any Danger in Bypassing the Clutch Switch? TX_QtPi Classic T4Rs 10 04-04-2013 01:48 PM
Tint moonroof danger realyfishy Engines / Suspension / Wheels / Tires / Audio / Accessories 25 08-05-2005 12:08 PM
