Old 02-06-2019, 03:06 AM #1
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
How Circuit Opening Relay Works
PLEASE DOUBLE CHECK WIRE COLORS AND SCHEMATIC AGAINST YOUR OWN FSM BECAUSE SOME TRUCK WIRING MAY TRANSITION DURING A YEAR.
How Circuit Opening Relay Works - 22R-Eliable
The relay prevents unwanted, unsafe fuel flow (i.e., in case of an accident when fuel line ruptures, engine stalls, airflow stops and COR interrupts power to the fuel pump). COR is the thing that you'd hear click behind the glovebox when you're trying to start a first gen 4Runner. However, it does not affect cranking system.
(In 1986 Runner) COR is located behind glove compartment near speaker and blower motor. Someone had posted about moisture in COR. Possible because:
a) It's near some body seams,
b) Its below where windshield joins the frame- there could be a leak there, and
c) It's near right side wheelwell, where there could be leaks. There are 2 grommets there. One for engine harness, one for antenna. Check for leaks.
MAF-COR-Fuel pump circuit is below. Circuit Opening Relay (COR) has two normally-open contacts (open when no power is applied). Coil 1 of COR is energized by IGN switch while in START position. Once airflow is established due to combustion, MAF contacts provide ground to coil 2 of COR, keeps COR energized and its contacts closed, even after IGN switch is released.
1986 SCHEMATIC
1988 SCHEMATIC
To bypass AFM contacts Jump terminals of Fuel Pump Check Connector* (below) while ignition is on.
Coil 2 of COR will be connected to ground, C.O.R. will click, and good fuel pump with good connections will run. Fuel will flow IF fuel lines are not clogged.
If you suspect Air Flow Meter malfunction, where you hear, feel and smell combustion ONLY WHILE holding ignition switch in "START" position but STOPS WHEN YOU RELEASE THE KEY this is a good test.
Also a good test for C.O.R. coil 2 and contact, as well a fuel pump and connections.
* On 1986 22R-E, brown and green wires lead to connector. On 1988 Blue and BLACK. 1985, 1987 unknown to me.
Keywords: C.O.R. circuit-opening, how it works, circuitopeningrelay
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 04-03-2022, 02:20 PM #2
Fixxer1956 Fixxer1956 is offline
Fixxer1956 is on a distinguished road
On my 95 4 runner I have no start unless I jumper the EFI, COR seems to be ok, at least it operates properly when removed and checked. I’ve gone nuts replaced filter, fuel pump, problrms seems a bit intermittent, but if I jumper EFI, runs fine. Grrrrr
Fixxer1956 is offline   Reply With QuoteReply With Quote
Old 04-03-2022, 10:22 PM #3
RAD4Runner's Avatar
RAD4Runner's Avatar
Please clarify:
If you jump EFI relay it starts and when you remove the jumper it keeps on running?
Where do you jump the EFI relay?
coil , contacts , cor , fuel , pump
Need help with aux fusebox / circuit breaker / relay setup trailtruck Engines / Suspension / Wheels / Tires / Audio / Accessories 24 11-13-2019 05:48 PM
87 22RE circuit opening relay issue. warrpath4x4 Classic T4Rs 0 11-25-2017 07:52 PM
Sunroof Not Opening, Tilt Works, But Not Slide... the great him 3rd gen T4Rs 3 02-02-2012 07:02 PM
My ECU is reading code 11 Does anyone know where to find the Main circuit relay? 4RUNN3RJ Problems & Warranty Issues 1 10-19-2007 08:47 AM
