Yesterday i replace the older positive cable to a thicker one.. cause im gonna have some electric devices in this car as well... also prepared some feets for the supports for the sideplate. the negative one i need to install them when the sideplate is down... but i think the sideplate will mostly stay down anyway.
Quick question about your rust work, what is the yellow tinted product that you put on the repaired areas called?
It is a 1-comp thin layer of acid filler, mostly use to get the paint products to stick very well. it is good to use on aluminum as well.
It can stay on clean steel a longer period without beginning to rust again. So i use it mostly a day or longer before i paint over it or so. the brand is Sikkens and is called washprimer. only mixed with some thinner.
i love car audio, so i will use this enclosure local when im not out on adventure or so. it is not so big, big it takes place if i need bedplace also begin to upgrade some standard ground cables like tge groundwires from engine block.. will also upgrade to new cables from battery to chassies and also bigger batteryes. i Want to install solar panel or so later.
Not really much have happend, have spent my time to overhall my th400 tranny for my US car and other stuff.. snow is soon away so have just enjoyed some days to take the 4R out for some drive and visit friends.
Have also begun to make a budget tube bar protector for a ledbar im gonna have on the bumper later.. for now im using a Cobra bar. Some pics.
So the new bar is installed, very easy to add or remove.. would be stronger to weld it om but not for now.. now i will see if i can find a good ledbar or so that fit inside it.
