Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 02-14-2021, 06:26 PM #76
4RunnerSafari's Avatar
4RunnerSafari 4RunnerSafari is offline
4RunnerSafari will become famous soon enough 4RunnerSafari will become famous soon enough
more..
Sent fra min WAS-LX1 via Tapatalk
4RunnerSafari is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 06:32 PM #77
I wanted to have a wice with me in the future on the travelings if nessesary,, so i welded together a wice holder for my towing point, in should clear the bumper when it comming on.. hopefully..
Old 02-16-2021, 04:27 AM #78
Wheelbearing and lockrings on shaft. just banging it down with a steelpipe i made. works every time. Milneroffroad sending one extra lock ring in each wheelbearing sets, so i use one to make bigger inner dim so i could use it as a guide with out hanging, the old one was to bad to use anyway. these parts will be good to save for later as well.
Old 02-20-2021, 11:32 AM #79
new post below..
Old 02-20-2021, 05:23 PM #80
Soo ready for new gasket, the diff lamels looks pretty good still. the gears looks great too so the diff have lived a good life.. had to fix some of the bolts before i install them with threadlock as well..
Old 02-21-2021, 01:51 PM #81
Got some time today to install and torq it down. Include the superthin original gasket i took on some thin layers of rtv silicone as well... as pic may show..
Old 02-26-2021, 08:55 PM #82
Last bearing and lock ring on earlyer this week, axle assembled, brakeparts prepared last night.
Old 02-27-2021, 07:30 PM #83
Was going to paint today, but found some rust on the front door i had to replace with new steel.... anyway brakeparts got on today as well..
Old 03-05-2021, 07:25 AM #84
Rims ordered.
Old 03-05-2021, 06:09 PM #85
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
just curious how much steel you have replaced on this thing weight wise?
I admire your dedication!
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 07:03 PM #86
Hah, hopefully not to much to increase the total weight of the car 4R from North, *Accessories build time.
Thanks.
Old 03-05-2021, 07:06 PM #87
So i decide to paint a bit tonight. mainly bumpers braking back plates, axle and some on the frame.
Need to do the finish on the inside door a bit nicer later.
Old 03-07-2021, 09:52 AM #88
So after the first coat on Friday with a struggling paint gun, i re-mask around again with new (blue) tape to overlap the paintline and cover over the yellow epoxy spots that shown..
I put on second coat today with a new spraygun, the layer got a bit thicker now.. and also sprayed a bit on the frame and where i have remowed some rust earlier under the floor..
Will have a wax surface layer at the end.
Old 03-09-2021, 05:50 PM #89
Brakelines on
Old 03-11-2021, 05:42 PM #90
Prepared the brakeshoe clearence and set it to a tight 0.8mm before the cable will be attached. Standard clearence will be 0.6mm.
The new drums got a first layer of caliper paint as well..just to hold the rust out for a while.
chapter , fender , frame , install , rust
Whose from North Carolina? matthinnant Off Topic 45 10-26-2020 09:25 AM
North MS dkerr (The Rest of) The Deep South 1 02-17-2018 11:46 AM
New from North Carolina Briar New Members 2 12-08-2014 09:38 AM
Greetings from the Frozen North djruuh New Members 0 12-01-2014 09:57 PM
North Alabama? rleary360 General Discussions 3 02-05-2013 09:19 PM
