Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 07-12-2020, 06:59 PM #46
4RunnerSafari's Avatar
4RunnerSafari 4RunnerSafari is offline
4RunnerSafari will become famous soon enough 4RunnerSafari will become famous soon enough
Fixing rust on rear axle, shock mounts.
Sent fra min WAS-LX1 via Tapatalk
4RunnerSafari is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 07:05 PM #47
Panhard mount fixed and done. Did a bypass for water and dirt under the spring seat so it will not go in to the mount. the 2 holes underside will be covered with 2 plastic plugs after spraying in fat so it will not rust.
Old 07-12-2020, 07:11 PM #48
New springseat cups for the body.
Old 07-12-2020, 07:17 PM #49
Some old exhaust fix and a picture of the frame where it is finish.
Old 07-25-2020, 09:37 AM #50
The new bumperstop cups are ready to weld in, i make a drain hole aswell if it will comes water down there later, anyway noe i can grease it inside to protect it from rust. the original is a rust trap, mine was full of water when i make holes in them. I bought a new rubber boob cause i missed one.. expencive but worth it.. the other one i cut a new disk and glued it on, so i can reuse it.
Old 07-25-2020, 07:42 PM #51
Got time today to weld in those bumper cups.
This time i decide to grind down those welds flush with the steel..
Old 07-29-2020, 05:50 PM #52
Frame is done... i think.. tailgate next! preparing new metals that goes in.
Old 07-29-2020, 11:32 PM #53
T4rRVAx2's Avatar
T4rRVAx2 T4rRVAx2 is offline
T4rRVAx2 is on a distinguished road
T4rRVAx2's Avatar
Impressive restoration! The frame on mine was way worse when I got it, and I did debate trying exactly what your doing. Although after seeing the amount of detail and work you did, I'm glad I was able to find a rust free frame. Cant wait to see more pictures!
'03 Limited V6 Pacific Blue | 06-09 Headlights w/LEDs | 20% Tint | 5th Gen Brake Upgrade | Stealth LED light bar | 06-09 Limited Wheels | LED Bulb Swap | Weathertech | Grom Audio aux input |
'89 SR5 V6 Dark Gray | Restoring |
T4rRVAx2 is offline   Reply With QuoteReply With Quote
Old 08-08-2020, 04:53 AM #54
Thank you,
So the tailgate is finish welded, i think i will trow on some 2k epoxy primer, since part of the car will have a new paint anyway.
The new metal plates i make new holes for the window rubber list mounting clip as well.. wrong way on the picture btw.
Old 08-28-2020, 03:39 AM #55
Fixing the doors and took out the headlights for a paint to get a darker look
Old 08-29-2020, 05:39 PM #56
davewaner41's Avatar
davewaner41 davewaner41 is offline
davewaner41 is on a distinguished road
So what actually needed here
Sent from my TECNO KA7 using Tapatalk
davewaner41 is offline   Reply With QuoteReply With Quote
Old 09-12-2020, 06:20 PM #57
Rearend sandblasted, got it home and added some bracings and coat it with Zinga galvanizing layer.
Old 09-13-2020, 02:28 PM #58
Last coat today
Old 09-13-2020, 10:00 PM #59
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
W - i - l - d !!!
Old 10-07-2020, 06:28 AM #60
Begun to sand down the lower part of tailgate door, cause i want to paint most possible when it is ready, doors, fenders etc.. the axle and upperpart on the tailgate is ready for paint after some layers of 2k epoxy primer.
chapter , fender , frame , install , rust
Whose from North Carolina? matthinnant Off Topic 45 10-26-2020 09:25 AM
North MS dkerr (The Rest of) The Deep South 1 02-17-2018 11:46 AM
New from North Carolina Briar New Members 2 12-08-2014 09:38 AM
Greetings from the Frozen North djruuh New Members 0 12-01-2014 09:57 PM
North Alabama? rleary360 General Discussions 3 02-05-2013 09:19 PM
