Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 04-10-2021, 02:06 PM #106
4RunnerSafari's Avatar
4RunnerSafari 4RunnerSafari is offline
4RunnerSafari will become famous soon enough 4RunnerSafari will become famous soon enough
New oil on rear diff, bumper holders installed, all brakelines are connected and ready for bleeding, wheel houses got some butyl sound deadning.
Have more pics of other works but not done yet..
Sent fra min WAS-LX1 via Tapatalk
4RunnerSafari is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 04:55 PM #107
Today i begun to add sheep fat inside holes and inside the rearpart of the frame..the bumperstops, the rear panhard mount box on the axlw and up in the floor around..
Installed the heat shield for the muffler. and added a finish coat on the filling tube for the diesel. Also drilled out a broken bolt and re-thread it, for the fuel tank hanger, from M8 to M10..
Old 04-16-2021, 05:39 PM #108
After fixing brakes on another car i have earlier today, i begun to extend the rear links for the stabilizer bar this evening.
Bought 2 new one, and welded together with a old link that had the same diameter rod. Extended them 30mm so the swaybar have the same angle as the lower link control arms..think that should work.
The old ones was extended also by another older owner, but was a bit long.. and was thrash.
Need some paint at end.
Old 04-29-2021, 04:59 PM #109
New paint on the shocks, also bought a new original muffler. im lazy to weld the old one, it was one tiny hole that became superbig rusty one... maybe will fix it later.. right now im focused to get it done.
Fuel tank is on, and the shield,filling hose are on.
Old 05-02-2021, 03:16 PM #110
Today i decide to fit and weld the endpipes,installed the new muffler the day before.
Old 05-03-2021, 02:25 AM #111
OzSurf OzSurf is offline
OzSurf will become famous soon enough
Amazing how much work you've put in to this thing so far, I wish I could weld half that well. Those swaybar end links came up great.
OzSurf is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 04:49 PM #112
Thank you for kind words, it have been a journey for sure. lol.
Visit the garage today again to finish the exhaust pipe rear hanger and mount it to the muffler with new gasket, sits pretty solid now.
Installed the wheels so i can put it on the ground very soon.
Old 05-12-2021, 11:50 AM #113
4RunnerNorway 4RunnerNorway is offline
4RunnerNorway is on a distinguished road
Hva har du malt hjulbuene med?
4RunnerNorway is offline   Reply With QuoteReply With Quote
Old 05-16-2021, 06:04 PM #114
@4RunnerNorway Det er Hagmans sin dempemasse, selger den på billakk.no
So since the rear end is on the ground i begun in front. my new rims from the U.S also arrived a few weeks ago.
Since the wheelbearings is still ok i just repack them with new grease and add a new seal, and will bring new bearings in the car instead.
Had to do a emergency fix on the lower control arm until i will get 2 new later was to cut out and weld in some new steel on the rear. these cars need really some attention for some wash and keep the drainageholes open around or it will be a disaster with the time..
Old 05-16-2021, 06:14 PM #115
Fresh up the towbar a bit as well.
Old 05-23-2021, 04:04 PM #116
Random
Old 05-24-2021, 11:41 AM #117
Tought i had a bad carrier bearing if my front diff...but forgot the hubs have some needle bearing in there.. i guess the hub could be replaced so the tolerances would be a bit tighter.
Anyway i changed the needle support bearing today and got a bit tighter tolerance. Also inspect and regrease (a lot) the front driveshaft and installed it.
To guide in the needlebearing i use the Hub as a guide without the c-clips, then use a 30mm socket to carefull bang the rest in.
I use a flat screwdriver that i grind very flat so i could get it under the old bearing, i pre heat it first.
I don't have any puller yet so that was the easyest way. Works ok.
Old 05-27-2021, 03:39 AM #118
Spindles got some work as well.. more work to come this weekend.
Old 05-28-2021, 03:40 AM #119
Painted the rear bumper parts yesterday, did coat on the side as well.
Was not so happy about the first coat.
Old 05-28-2021, 07:06 PM #120
Run in to a seal problem today, those i bought from rockauto are to big.. i think they are for Hiace knuckle/spindle.. iv contact them so we can find a solution.
Asseble the last cv axle as well after getting a new missing C clip that did not was on the axle at all..
chapter , fender , frame , install , rust
Whose from North Carolina? matthinnant Off Topic 45 10-26-2020 09:25 AM
North MS dkerr (The Rest of) The Deep South 1 02-17-2018 11:46 AM
New from North Carolina Briar New Members 2 12-08-2014 09:38 AM
Greetings from the Frozen North djruuh New Members 0 12-01-2014 09:57 PM
North Alabama? rleary360 General Discussions 3 02-05-2013 09:19 PM
