Old 02-20-2020, 08:53 PM #1
Snypr18's Avatar
Snypr18 Snypr18 is offline
Snypr18 is on a distinguished road
Snypr18's Avatar
3.0 V6 Lifespan?
Anyone have input on what sort of lifespan can be expected from the 3.0 V6 in 1st and 2nd gens? If you were buying one, how many miles would be too many for you to consider?
Any maintenance (preventive or otherwise) procedures you would perform immediately on one with uncertain maintenance records?
Snypr18 is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 11:27 PM #2
broad.named.maude broad.named.maude is offline
broad.named.maude is on a distinguished road
3.0 lifespan
I got my '88 SR5 with no maintenance records and 220,000. I have no idea if it was well maintained before I got it a couple years ago. It ran fine and was nearly rust free, so I got it. I think with regular maintenance it can be expected to last another hundred thousand, maybe more.
broad.named.maude is offline   Reply With QuoteReply With Quote
Old 02-21-2020, 10:20 PM #3
Snypr18's Avatar
Snypr18's Avatar
How many miles are you at now? Have you done any major maintenance such as head gaskets or valves?
Old 02-24-2020, 05:50 PM #4
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Mine's at 223,000 miles, no issues. Due for a timing belt and probably a valve adjust. Those are the two things I would consider as maintenance beyond the standard fluids, plugs, etc. if I had one without a history.
Mine shows no signs of quitting, and still has normal power, so I don't know how long it might last. I only drive it 5-6K miles per year anymore, so it'll likely outlast my need for it.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 10:32 AM #5
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Just dont let them over heat and change the oil and youll be fine.
I rebuilt mine close to 8 years ago now, and it is still going strong in my crawler.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 12:31 AM #6
jay333 jay333 is offline
jay333 is on a distinguished road
Get the 4cyl 22RE model if possible - I have over 260,000 miles and the only thing I have ever replaced (other than fluids) is a clutch and a few light bulbs.
jay333 is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 12:05 PM #7
MAG GRY TACO15 MAG GRY TACO15 is offline
MAG GRY TACO15 is on a distinguished road
I use to have an 88 with the 3.0 It popped the head gasket at 200k. The head wrapped and the motor needed to be replaced. Toyota actually paid for this as part of an extended recall. The 2nd motor is still going as far as I know after 100k on it. It's got a new owner as of last year.
MAG GRY TACO15 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 12:29 PM #8
Eacook1's Avatar
Eacook1 Eacook1 is offline
Eacook1 is on a distinguished road
Eacook1's Avatar
My Head gasket was replaced by the dealer at 67k. That gasket lasted until 230k. I had the engine rebuilt and when my machinist pulled the engine apart he said it looked perfect and could have easily gone another 200k. Point being if maintenance has been done the engine is solid except for the head gasket. My new engine now has 260k.
Side note. My machinist said the block/head surface had some erosion. If you just throw a new gasket on there without decking the block then it likely wouldn’t last 30k before the gasket blew again.
1993 T4R 5 SPEED
Eacook1 is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 07:11 AM #9
fastgtfairlane fastgtfairlane is offline
fastgtfairlane is on a distinguished road
Bought my 94 3.0 4x4 5spd about 5 years ago with 200k on it. I'm at 298k now. Engine still runs fairly well. It does leak and burn a little oil. To my knowledge the head gasket recall had been done before I bought it. It doesnt run hot. I did have the timing belt go out on me at like 260-270k looked to be original. Water pump and all pullies under the cover were seized. Haha. The engine develops a little noise when getting low on oil. I haven't done best oil change maintenance on it either 🙈. Overall it's been a pretty problem free truck. Yes its slow but torquey and will go anywhere. The engine us starting to get a little tired. Kicked around with the idea of upgrading to a 3.4L but I think a solid 3.0 would be plenty. I've been very happy with my 4runner. If it was an auto trans I'd probably have different feelings about it though haha
fastgtfairlane is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 10:40 PM #10
Threepointno Threepointno is offline
Threepointno is on a distinguished road
The one I just got popped the head gasket at 250k and a new replacement engine was put in. It was meticulously maintained and I have a stack of records 3” thick dating back to 93’ I’m working on getting the parts to complete the 3.4 swap as I know this one will eventually pop.
Threepointno is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 06:02 PM #11
Ole Red 93 Ole Red 93 is offline
Ole Red 93 is on a distinguished road
Got mine 2 years ago with 235k on it. As far as I know it had the head gaskets replaced, timing belt etc. since then I’ve had to have valve cover gaskets replaced, ac idler pulley and numerous other things done. Burns oil and has a leak at the rear main seal. I now have 247k and if I had known better, I would have bought a 3rd gen or later. Too slow and gas mileage is ridiculous. Live and learn. Would love to sell but I’ll never get back what I have in it.
Anyone in southwest Missouri know where I can get a limited slip third member?
Ole Red 93 is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 04:07 PM #12
Howitzer's Avatar
Howitzer Howitzer is offline
Howitzer is on a distinguished road
Howitzer's Avatar
I've had mixed experiences with the 3.slow. I had one in an 89 pickup with 439000km, and it would burn rubber into third gear. I was blown away, had never seen a 3.0 like that before, and haven't since. It looked factory for the most part. Had another in a 92 pickup and it made it through 389000km when I sold it, it was reliable but gutless. Then we just bought a 90 pickup for my wife with 272000km on it, almost half the mileage, and has a head issue- 0psi compression on cylinder 1 and 88% leak down through the exhaust valve. Haven't pulled the heads yet, but it almost seems like its the luck of the draw, thermal cycles and maintenance schedules
87 4Runner Diesel swap in progress- stay tuned for writeup
If Nobody From The Future Comes And Stops You, How Bad Of A Decision Can It Really Be?
Howitzer is offline   Reply With QuoteReply With Quote
immediately , lifespan , maintenance , perform , procedures
3rd gen lifespan shoota 3rd gen T4Rs 107 10-19-2016 03:09 AM
Lifespan Q. Mellemel 3rd gen T4Rs 6 12-28-2015 02:18 PM
lifespan of a coil over? noobshooter Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-11-2012 05:57 PM
2004 T4R lifespan question 3dogs 4th Gen T4Rs 6 08-31-2011 10:25 PM
x-reas lifespan? afx604 Off-Roading 21 11-13-2008 11:04 PM
