04-05-2013, 09:24 PM
Real Name: Aram
Real Name: Aram
BaseRunners 1989 22RE Build thread
Well hello fellow 1st generation owners, I just bought this beauty today 4/5/2013. It needs a new timing chain and it has some rust. I plan on sanding the rust off pretty good and using some rust treatment. Then I plan on plasti dipping the WHOLE ride black! Any suggestions by you guys for what else I should do with it would be greatly appreciated it! Oh and I have a 2000 3rd generation which is my daily driver, this 1st generation will be the weekend ride!
2000 Toyota 4Runner 4 Cylinder 2.7L 2WD on 31x10.50x15s Build thread --> http://www.toyota-4runner.org/3rd-ge...ld-thread.html SOLD!!
1989 Toyota 4Runner 22RE 2.4L 4WD on 31x10.50x15s Build Thread --> http://www.toyota-4runner.org/classi...ml#post1348761
04-07-2013, 03:30 AM
Real Name: Kevin
Real Name: Kevin
Boo plastidip, you need to bring that factory paint job back!
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
04-07-2013, 11:56 PM
Real Name: Aram
Real Name: Aram
Lol man I wish I could do that, but I dont have the money to do that. Plus this is gonna be the weekend warrior, im going to be going mudding crawling and all that good stuff. So its gonna get all scratched up...plus Plasti dip is affordable lol. I dont know what to do about some of the rust though.
04-08-2013, 12:06 AM
http://www.rustoleum.com/CBGProduct.asp?pid=367
Try this. Cheaper than plastidip, resists scratches nicely and has a cool sand paper like texture. With a light sanding first, it holds great.
Originally Posted by dorton
I wish I had a 2nd gen.
Originally Posted by BucknutBob
I find myself wishing I had waited and picked up a 2nd Gen instead
I want to convert my '85 to IFS.
04-08-2013, 12:07 AM
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Get a wire wheel and clean up the rust. Spray some por15, chassis saver or whatever your favorite rust treatment is on the rust. That will stop the spread of the rust. Stay away from plastidip. I haven't ever seen good results from it. I have never used it but anything that I have seen with plastidip on it has looked crappy and the paint has peeled after a very short time. If you're going to repaint it then use a rustoleum paint and make sure you do your prep work.
Either way you go, take lots of pics and post your progress!! Congrats on the new runner!!
04-08-2013, 12:14 AM
Real Name: Aram
Real Name: Aram
Originally Posted by Footofgod
RustOleum.com
Thats a interesting idea, thanks im gonna think about that.
Thanks man, and I appreciate the tip, Im going to try and get this rust off and think about what im going to go with. But first things first, I need to change the timing chain and have this baby up and running. Everyday I walk out of my house I look at it and get sad that its just sitting there and not being driven on a mud trail or something lol.
04-08-2013, 12:31 AM
Just grab a grinder and saw zall and cut it all off. Wheel with whatever is left.
04-08-2013, 01:25 AM
Real Name: Aram
Real Name: Aram
I think im gonna just sand the hell out of it and just treat it and spray over it. That will still keep the truck intact. Its not too much, the only considerable amount of rust is on the driver side by the back tire. Other then that its pretty good underneath and other places. But that spray you recommended might come in handy!
04-08-2013, 11:44 AM
Real Name: Aram
Real Name: Aram
Sorry guys noob question here. I noticed my brake fluid is really really low! I was wondering would any type of brake fluid be good? or is there a special type of brake fluid for these classic runners?
04-08-2013, 12:09 PM
After you get engine running, address the known issues with these classics, to name a couple: - Rear suspension sag,
- Intermittent click-only starting issue,
- Dim headlights because of thin wire and unnecessarily long current path, which also burdens dimmer switch with high current (not ideal, and as high as 17 amps with 55/100 bulbs)
Standard DOT-3 is good.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
04-08-2013, 12:36 PM
Real Name: Aram
Real Name: Aram
Thanks for the tips man! much appreciated!
04-11-2013, 11:30 AM
Real Name: Aram
Real Name: Aram
I just went out to try to get my runner started. When I put the key in it wont start!!...the day I brought it home it started fine with no problems. Now I must say the day I brought it back I didnt know about the push button release for the ignition key so I just pulled it out of the ignition...did I mess something up? whats wrong with my runner??
04-11-2013, 11:41 AM
Real Name: Kevin
Real Name: Kevin
Do you get a click when you turn the key? Sounds like it's coming from the passenger kick panel?
04-11-2013, 11:50 AM
Real Name: Aram
Real Name: Aram
Yea I did...I was kinda wondering what that click was.
