Old 05-30-2019, 10:09 PM #1
Eugene13's Avatar
Eugene13 Eugene13 is offline
Real Name: Daniel
Eugene13 will become famous soon enough
Eugene13's Avatar
Real Name: Daniel
Battery light still on after replacing alternator
Sup guys. Alternator bit the dust, most likely because of an oil leak. I suspected that as my "CHARGE" light has been flickering as I'd get above a certain rpm for about a week now, but then it went away for a few days. The light then reappeared again yesterday, but now it was staying on constantly. Took it to the autoparts store and their battery/alt tester is broken Went to a different autoparts store and their battery/alt tester is also broken So me figuring it was the alternator took it out of the truck and took it to the store to have them bench test it, came up bad, but I ended up getting a free one as a warranty from the manufacturer . Replaced it today, along with some wires that were in rough shape, cleaned all the connections and fired it up. Light still on. Put a volt meter on the battery and it is charging. (idled for about 15 min and went from 12.4 to 13.7 volts). Not sure what to do. I have yet to drive it around and won't be able to till tomorrow. Any ideas on why the light is on? P.S., I fixed the oil leak, stupid distributor o ring.
Eugene13 is offline   Reply With QuoteReply With Quote
Old 06-02-2019, 02:19 PM #2
Eugene13's Avatar
Real Name: Daniel
Eugene13's Avatar
Real Name: Daniel
ok so now I am at a loss. I've checked every ground and they all have good connection. I'm getting power from the alternator and it's making it through every plug, every wire, and getting to the battery. Voltage regulator checks out okay. I have checked the CHARGE fuse and it's fine. I checked the charge lamp relay and that's fine. I really am just completely at a loss of what to do at this point. Does anyone have any suggestions?
Old 06-02-2019, 08:57 PM #3
Eugene13's Avatar
Real Name: Daniel
Eugene13's Avatar
Real Name: Daniel
I fixed it. it was the voltage regulator. I'm glad that it was that cause that was my absolute last resort before taking it to somebody.
Old 06-03-2019, 01:34 PM #4
pinemind pinemind is offline
pinemind will become famous soon enough
Just for the rest of us and future reference, where exactly is the voltage regulator on 1st gen 4runners? In all my perusing of the FSM/parts diagrams, I have yet to come across it.
pinemind is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 12:34 PM #5
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Built inside the alternator.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 06-13-2019, 02:55 PM #6
Eugene13's Avatar
Real Name: Daniel
Eugene13's Avatar
Real Name: Daniel
Not on my 84, at least, its a small rectangular box with wires coming out of it on the drivers side of the engine bay, behind the power steering fluid reservoir.
alternator , autoparts , battery/alt , light , store
1999 4Runner Battery Light - Alternator? Ty4Runner 3rd gen T4Rs 6 09-03-2022 05:00 AM
Battery light on...time for an alternator woodman60 4th Gen T4Rs 6 11-05-2018 06:06 PM
Help! New Alternator Battery Light on when Cold Badbob 3rd gen T4Rs 9 01-17-2016 09:55 PM
Battery light/alternator problem darkgun82 4th Gen T4Rs 6 12-21-2014 05:13 PM
Replaced Alternator but battery light is still on. GypsyRose 3rd gen T4Rs 4 09-20-2013 12:49 AM
