Old 04-22-2019, 05:06 PM #1
Jiggit Jiggit is offline
Jiggit is on a distinguished road
Starting for the first time in 10 years
Ok so my dad gave me his 91 4runner as long as I got it out of his garage. I had it towed to my place where I'll finish the body work on it and make it my new work vehicle. Here is the problem it hasn't been started in a little over 10 years. I've done some research on the web and found a few lists of things to do but I wanted to get this groups input specific to this year 4runner. Here is my plan of what to do so far:
Drain Gas
Change Oil
Take out spark plugs and put some machine oil the heads and let sit overnight
Put in some ethanol free gas with injector cleaning additive
Fill the radiator
Replace battery (Done)
Try to start it up!
Assuming it starts up take it to local lube shop and have them do all the fluids except the oil that I'll already done myself.
I should also mention it was running fine when he parked it.
Please let me know if I'm missing anything
Thanks in advance.
Jiggit is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 03:24 PM #2
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
The protective oil film will be pretty much gone from every internal surface of the engine. You need to try to restore that film as much as possible before actually running it. I would suggest, while you have the plugs out, putting a wrench on the crank bolt and turning the engine a few times to get everything unstuck. Then, again before you put the plugs back in, crank it with the starter for a minute or two to build oil pressure and let lubrication flow before you actually run it.(Pull the EFI fuse while you do this to keep the injectors from spraying fuel and the ignition from firing.) Finally, put the plugs back in, replace the EFI fuse, and try to start it. If/when it starts, let it idle for a good 5 minutes before racing the engine at all.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 04-27-2019, 12:13 PM #3
Update
It didn't start. I'm pretty sure it's just not getting fuel because when I sprayed starter fluid into the engine it started to run.
Next step is to figure out if the fuel pump is working does anyone have any suggestions?
Old 09-09-2019, 09:02 PM #4
Heathen_S13 Heathen_S13 is offline
Heathen_S13 is on a distinguished road
I too am in the process of getting an old rig running after sitting in a field for a little over a decade. Mine is an 86 tho.
Did you ever get yours running? What was the issue? Anything else you would recommend doing before starting it?
I kno the years are different, but so far I have pretty much the same idea
Heathen_S13 is offline   Reply With QuoteReply With Quote
starting , time , years
Not starting each time I get gas Laidflat 3rd gen T4Rs 36 01-08-2024 12:07 AM
Started truck for first time in three years. Philbush1127 3rd gen T4Rs 16 03-19-2016 08:10 PM
99 4Runner not starting all the time catnip76 Maintenance/Detailing 4 08-28-2014 04:15 PM
Occasional hard time starting. Jasonredwood 3rd gen T4Rs 6 05-23-2014 10:40 PM
Starting a vehicle that's sat for 5+ years? Clemsonfan15 All Other Vehicles 9 06-28-2011 09:05 PM
