Old 05-19-2019, 08:57 AM #16
WOODMAN1465's Avatar
WOODMAN1465 WOODMAN1465 is offline
WOODMAN1465 is on a distinguished road
Nice 4runner...
WOODMAN1465 is offline   Reply With QuoteReply With Quote
Old 05-19-2019, 02:13 PM #17
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I decided to get a better on-board air compressor. The one the original owner installed wasn't a constant duty air compressor like you would want when filling 37 inch tires. The original compressor could only run for 20 minutes before needing to be cooled off for 20 minutes. I already own a Viair constant duty portable compressor so I decided to upgrade the compressor on this rig to a Viair 450C constant duty compressor as well. This compressor is nice upgrade not only for the constant duty if offers but it will turn off when the system reaches 150 psi. The old compressor would just run and run until you turned it off maybe because it was really tired and could never achieve the 150 psi rating it had.
I know with the location under the rig being exposed to the elements isn't ideal but a quick check of the side compartments in the cargo let me know the compressor wouldn't fit in there without some type of modification. So, under the rig it went. The original mounting plate wasn't going to work so I had a fabricator local to me help me make a new plate for the installation.
I wasn't sure which way I wanted to go with an air hose to use, but for now I'm using a heavy duty rubber line from Home Depot. It's way longer than I need, 50', but I thought this length might be nice to have if you had a person in your wheeling group that needed some air and the extra long hose would reach all 4 tires on their rig as well without having to reposition it. That hose is pretty bulky but it does fit in my passenger side cargo compartment. I think ultimately I'll convert the supply hose to one or two accordion style hoses like Viair supplies with their portable compressors.
Timmy Now Has a 1st Gen-air-comp-1-jpg
Timmy Now Has a 1st Gen-air-comp-2-jpg
Timmy Now Has a 1st Gen-air-comp-3-jpg
I'm not too familiar with these push to connection air lines but the straight fitting on the one shown in this picture is leaking. It seems they are used for lots of application so I guess they are legit. I ordered some new fittings and tubing so I can hopefully get this system leak free.
Timmy Now Has a 1st Gen-air-comp-4-jpg
Old 05-20-2019, 05:20 PM #18
Ida4runner Ida4runner is offline
Ida4runner will become famous soon enough
Very Nice! hows it drive with those tires?
Ida4runner is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 10:40 PM #19
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Drives pretty good. The guy who built the rig stretched the front end by a few inches. The steering arms are perfectly parallel with the front end making the steering pretty damn easy. It does like to pull a little to the left so I need to get it into an alignment shop to check the toe.
Old 05-29-2019, 11:20 AM #20
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Here's a video introduction to this rig. Hope you enjoy it!
Old 06-13-2019, 08:50 PM #21
MBZ300CD's Avatar
MBZ300CD MBZ300CD is offline
Real Name: Gary
MBZ300CD will become famous soon enough
MBZ300CD's Avatar
Real Name: Gary
Nice 4Runner and a bargain at 12k. Also, thanks for your videos. Bro-dozer?
1987 4Runner 22RE 5 spd
Gary
MBZ300CD is offline   Reply With QuoteReply With Quote
Old 06-14-2019, 12:37 AM #22
Cali 4runner Cali 4runner is offline
Cali 4runner is on a distinguished road
Nice!
Man that body was clean before :/
Cali 4runner is offline   Reply With QuoteReply With Quote
Old 08-09-2019, 07:08 PM #23
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
New Personalized Plates. What do you Dudes think?
Timmy Now Has a 1st Gen-personalized-plate-jpg
Old 08-09-2019, 07:41 PM #24
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I would have gladly bought that for 12.5k… I really need to keep an eye out for things like this.
Old 08-11-2019, 06:57 PM #25
larson189 larson189 is offline
larson189 is on a distinguished road
looks great!
larson189 is offline   Reply With QuoteReply With Quote
Old 08-17-2019, 11:35 AM #26
Jimmy Two Dogs's Avatar
Jimmy Two Dogs Jimmy Two Dogs is offline
Jimmy Two Dogs is on a distinguished road
I can't hit the "Like" button enough for this 4Runner! Wow! I love this!
Jimmy Two Dogs is offline   Reply With QuoteReply With Quote
ago , bought , gen , rig , years
Look What Timmy Bought mtbtim 3rd gen T4Rs 65 06-28-2019 10:38 PM
100th Video for Timmy the Toolman & Sean mtbtim 3rd gen T4Rs 22 12-14-2018 12:34 PM
Timmy the Toolman Show hits 10k Subscribers! mtbtim 3rd gen T4Rs 26 09-24-2018 05:18 PM
Mod Day at Timmy the Toolman Studios mtbtim 3rd gen T4Rs 17 11-02-2017 12:57 PM
