Old 11-03-2019, 10:26 AM #46
4Reak Show's Avatar
4Reak Show's Avatar
Ended up knocking out the cruise switches last night
Before
After
It's the little things...
For Christmas I'm gonna get a new steering wheel cover from wheelskins. That's gonna be badass.
Old 11-04-2019, 06:07 PM #47
Chazzmatazz's Avatar
Chazzmatazz Chazzmatazz is offline
Chazzmatazz is on a distinguished road
Looks good! I just wish my cruise control actually worked!
1995 SR5 4Runner | 3.4L 5VZ-FE | 5 Speed | Daily Driver
Chazzmatazz is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 11:53 PM #48
4Reak Show's Avatar
4Reak Show's Avatar
Thanks. You have the 3.4 swap as well correct? I solved the issue with mine. I can help diag if you'd like.
Old 11-04-2019, 11:55 PM #49
4Reak Show's Avatar
4Reak Show's Avatar
So I got antsy and hooked up the Ultimate Camping mod by adding the constant power back window switch. I just tapped into the same wires that runs the tailgate key switch. Easy enough. Ran wires up the D pillar and around to the center finish trim. Little chop chop and it slid right in.
Now I can roll the back window up and down any time I want from the inside. Beats having to lean over, turn on ignition and then run switch from center console.
Old 11-06-2019, 07:50 PM #50
Folsom4Rnr's Avatar
Folsom4Rnr Folsom4Rnr is offline
Real Name: Brian
Folsom4Rnr will become famous soon enough
Folsom4Rnr's Avatar
Real Name: Brian
Wish I could've gone that day... totally bummed I couldn't make it out.
Originally Posted by 4Reak Show View Post
Just finished a WONDERFUL (but long) day trip to the Mattley Ridge area. Holy friggin moly. Thanks to @Folsom4Rnr for sparking the idea. Another thanks to @dietsoap for still wanting to make it happen. Super cool meeting you and your family man. And the dude has a TANK of a sequoia. Sqeeeeeeezing it through some tight spots like a boss. And of course thanks to @Avidflyer for bringing the beast out of the cave for some fun.
14 hrs, 350 miles. Had a couple back tracking moments but we completed what I mapped to be about a 15 mile loop
About 8,000 feet at the top. And one spot had to have had an 18% grade. STEEEEEP. But fun as hell.
Time for a Budweiser.
2006 Limited V8 in Titanium Metallic
Build and misc. adventure thread
Folsom4Rnr is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 09:52 PM #51
4Reak Show's Avatar
4Reak Show's Avatar
It's a great area. Dozens of trails and places to explore. So if you ever wanna go again and we can arrange, I'd be down to go back.
Old 11-10-2019, 12:18 AM #52
4Reak Show's Avatar
4Reak Show's Avatar
Bucket listed Strawberry Pass today. It has some gnarly spots. The 4Reak got hung up a few times, tapped the skid plate, slid on a slider but came out on the other side. Great over nighter and day trip. 8500 elevation according to Gaia.
@dietsoap @Avidflyer @Folsom4Rnr
Old 11-11-2019, 10:29 PM #53
4Reak Show's Avatar
4Reak Show's Avatar
A couple pictures of the marks that the rocks left.
Driver slider
Factory front skid plate
And rear diff
Old 11-12-2019, 04:36 PM #54
Rnc1592 Rnc1592 is offline
Rnc1592 is on a distinguished road
This is such a sweet build!
Rnc1592 is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 08:27 PM #55
4Reak Show's Avatar
4Reak Show's Avatar
4Reak Show's build/use/nonsense
I call it The Reset: following an offroad trip I unpack everything, wash the outside and vacuum the inside. Then I fix anything that needs fixing. Since my average is about one trip every 6 weeks I don't like it sitting dirty in my garage. So I got to the reset after a week of craziness.
Repainted the slider that took some abuse, and pulled front skid plate to repaint.
I just wiped it down with rubbing alcohol and sprayed it a few times with rattle can. I don't see the need to make it totally perfect just yet. Turned out fine. Has a good little scar on it. Strawberry took its toll.
It's about winter time so coming up is going to be a big maintenance job. Oil change, clean K&N filter, change manual trans fluid to redline, change diff fluids, grease everything and full inspection for any other damage this season has brought. I did a lot of trail time. Most active year so far:
4/13: Poker flat (didn't finish, snowed out)
5/4: Hollister SVRA (Total joke of a place, and brake booster failed on the drive there)
6/15: Mormon Emmigrant (didn't finish, snowed out)
7/27: Poker Flat (Finished!)
9/3: Disneyland (in our 5th gen)
8/31: Mattley Meadow
11/9: Strawberry pass
Been a great year!
Old 12-01-2019, 12:22 PM #56
4Reak Show's Avatar
4Reak Show's Avatar
Christmas came early
Redline MT-90 GL-4 for transmission
Lucas heavy duty GL-5 for transfer case and rear diff
10 aluminum crush washers
Gallon pump
Jump start kit
Amazon: $168 total
Jump starter was $47! 1500A kit. Really nice too.
Old 12-01-2019, 08:44 PM #57
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
Gallon pump
Jump start kit
Amazon: $168 total
nice score!
I have a jump start kit under the front seat of my 94. Pulled it out to give someone a jump last year. It had been there for over a year and was still at 75% charge. They are a life saver
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 08:55 PM #58
4Reak Show's Avatar
4Reak Show's Avatar
Originally Posted by Dropzone View Post
nice score!
That's awesome. I carry jumper cables also but my purpose for this is a bit more selfish... I don't go out a lot alone, but it does happen, and will happen more. Well in that situation, jumper cables do you zero good. It's cheap and easy piece of mind. And it has USB ports for phone/device charging.
Old 12-02-2019, 01:36 AM #59
Redthies's Avatar
Redthies Redthies is offline
Redthies is on a distinguished road
Redthies's Avatar
I have one those jumpstart things. It was able to start my 6.7 Cummins when a battery failed on me on a fly fishing trip in the Bitteroot Mtns of Montana in October. It was cold as hell too. I was impressed!
I also put a leather Wheelskin on my 100 Series wheel. Super nice product for the money!
‘99 UZJ 100 factory locker with OME and ST Maxxs
‘89 VN60 with OME and BFGs
Redthies is offline   Reply With QuoteReply With Quote
Old 12-25-2019, 02:35 PM #60
4Reak Show's Avatar
4Reak Show's Avatar
Yeah it's crazy how much power is in those little battery packs. Pretty good peace of mind for cheap in a small package!
Funny you mentioned wheelskins... My mom is always looking for Christmas ideas for me so I told her what I wanted. She came through. I'm pretty excited to install it.
Merry Christmas everyone.
4runner , alright , conversion , cool , trans
Only 26th on this list? Nonsense! hikenbike General Discussions 11 11-26-2017 10:24 AM
2013 Los Angeles Auto Show and Tokyo Motor Show - 777 Photos trev0006 Off Topic 0 11-23-2013 06:35 PM
