Old 12-30-2019, 02:03 AM #61
4Reak Show's Avatar
4Reak Show is a jewel in the rough 4Reak Show is a jewel in the rough 4Reak Show is a jewel in the rough 4Reak Show is a jewel in the rough
4Reak Show's Avatar
Installed the wheelskins cover today.
Before (super faded, 25 years old)
After
Turned out really good. Great quality product. Doing the "spokes" were tricky as there isn't really a way to hide the thread. And if I were to do it again, I would probably wait for a warmer day. The material is a super tight fit so every bit of slack you can get would help. And now I sort of wish I had chosen black but the grey is a real close match. Overall, great improvement.
Old 01-07-2020, 05:48 PM #62
CamTom12 CamTom12 is offline
CamTom12 is on a distinguished road
Originally Posted by 4Reak Show View Post
So I got antsy and hooked up the Ultimate Camping mod by adding the constant power back window switch. I just tapped into the same wires that runs the tailgate key switch. Easy enough. Ran wires up the D pillar and around to the center finish trim. Little chop chop and it slid right in.
Now I can roll the back window up and down any time I want from the inside. Beats having to lean over, turn on ignition and then run switch from center console.
That's a great idea, I need to do that!
CamTom12 is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 11:45 AM #63
4Reak Show's Avatar
4Reak Show's Avatar
Registration coming up soon. Smog required. Took it and it passed yesterday no issue. 10 years on the 3.4 & manual swap and still going strong. (Of course having it BAR legalized makes it a breeze since everything is on the up and up).
Don't have to worry again for 2 years.
I did notice one of my rear tires looked wobbly while on the dyno. I have a big maintenance planned so that will get some extra attention... Strawberry pass was pretty rough on it.
Old 02-02-2020, 11:48 AM #64
4Reak Show's Avatar
4Reak Show's Avatar
4Reak Show's build/use/nonsense
Sometimes you're the windshield... Sometimes you're the bug
Doing some winter maintenance yesterday: oil change, K&N air filter cleaning, changed manual trans fluid to Redline MT-90, changed rear diff and transfer case fluids to Lucas Heavy Duty 80w90. I wasn't going to do the front diff but figured what the hell might as well do all the fluids underneath at the same time. Drained front and it looked brand new but I was already committed.
The drain plug was double washered! (Or so I thought). I beat the hell out of that second "washer" trying to get it off the drain bolt. Hacksaw, razor blade, screw driver, scraper. Nothing. So I went to order a new one and sonovab!tch they come with a washer looking thing on it molded to the head. F*ck. Oh well. Now I wait for the one from eBay. $14 lesson on that.
Old one I mangled terribly
New eBay picture
Notice the circle washer that's part of the new bolt. Now we all know. But I could have sworn the other drain plugs didn't have that piece.
Old 02-12-2020, 10:46 AM #65
4Reak Show's Avatar
4Reak Show's Avatar
Got the winter fluid maintenance done. Boring, but important. Haven't noticed much of a difference with the redline MT-90 but I've only driven it once.
On another note, noticed my CV boots tearing... AGAIN. I've decided I'm going to do the manual hub conversion while still keeping the ADD system. Sort of a hybrid. Just waiting for tax return money.
Old 03-10-2020, 09:46 AM #66
4Reak Show's Avatar
4Reak Show's Avatar
Tax returns came through. Decided to pull the trigger on something to save my CV boots from premature tearing. Driver side inner has about a 1" tear forming. Still totally functional and worth another few offroadings. These should slow the bleeding substantially since now it won't be spinning at 70 miles per hour
This also should save an MPG or 2 with less drag. Waiting on replacement center caps that are open instead of fully capped. Fun fact: brand new hubs don't come with base gaskets. Had to order those sepeately.
Old 03-12-2020, 02:10 AM #67
4Reak Show's Avatar
4Reak Show's Avatar
Did driver side tonight. Inner CV boot will thank me! I also opted to leave the ADD system intact. It has always worked great and now I can have 2wd low and have better maneuverability. Or I lock hubs on the trail and leave it until I head back home like it was prior. Never bad to have more options. And boy does it look awesome.
I would have started sooner but I was waiting for the correct wheel center caps. Had the covered ones prior, ordered open ended from Amazon but they were like 1.5" too long and would have been terrible. Ordered correct ones off summit and they got here quickly but cost a lot more. Gotta pay to play!
I'll do the other side tomorrow so I can drive it to work Friday and see if I feel a difference at all.
Old 03-14-2020, 02:55 AM #68
4Reak Show's Avatar
4Reak Show's Avatar
There is definitely a difference with the manual hubs driving. Not a whole lot, but it feels less draggy not having the CVs turning at 70 mph. So I'm glad I did it. Plus it allows for a more trouble free TrueTrac front diff upgrade potentially down the road...
Anyway, I'm knocking out some other nuances that have annoyed me or need addressing. Such as the subwoofer: I totally love the sound when I'm jamming to Led Zep and 98% of the time having it in the cargo area has no ill effects. However, those 2% of the time when I need the space for sleeping or hauling stuff it actually blows pretty hard being back there. And it's an entire unit with the amp and capacitor mounted to the sub box, but now it's easily removeable!
I used those massive quick connectors normally used for winches. My roof rack LED light relay box ran off the positive post that feeds the capacitor. So I crimped that main feed line into the new big connector on the truck side. Therefore, even with sub removed the relay box with still work.
Next up is to clean up the wiring under the hood a bit.
Old 03-15-2020, 02:39 AM #69
4Reak Show's Avatar
4Reak Show's Avatar
Due to this virus nonsense and the inclement weather my weekend free time was substantial today. So I tackled a project that has been nagging at me since I did the 3.4 swap ten years ago: the main battery wiring connection.
When I was young and dumb I made work what I had to, which included running a bolt through all main battery connection wires, taping it up and leaving it to float out in the engine Bay Area for the next decade. And to my credit, it held just fine! But looked terrible.
The red rubber cap on the right is the suspect connection.
Here it is with the cover and tape removed
So that went away along with some unused wires and installed is a killer buss bar to make everything incredibly cleaner
Had to extend some wires and rearrange some things but I'm pleased with it. And makes me feel a lot more comfortable for fire risk and such.
It's amazing what ten years experience and some patience will generate.
Old 03-21-2020, 01:44 AM #70
4Reak Show's Avatar
4Reak Show's Avatar
Old 03-21-2020, 11:48 PM #71
4Reak Show's Avatar
4Reak Show's Avatar
Came across a leftover LED light strip from work so I managed to solder wires to it and attach it to under my hood. A magnetic switch automatically turns it on and off with hood open or closed.
Suuuuper bright.
No more flashlight leaning on shit to see anymore. Can't recommend this upgrade enough.
Old 03-22-2020, 08:12 PM #72
OzSurf OzSurf is offline
OzSurf is on a distinguished road
Suuuuper bright.
I did the same with a strip across the front and have to agree it's definitely recommended. The magnetic switch is a great idea! Tidy looking 2nd Gen you've got there.
OzSurf is offline   Reply With QuoteReply With Quote
Old 04-17-2020, 10:21 AM #73
4Reak Show's Avatar
4Reak Show's Avatar
This COVID stuff sure does force a person to find things to do. I FINALLY fixed my clutch line issue that has bothered me for 10 years since the engine swap.
Again, I didn't know as much as I do now, and I was somewhat rushed, so the job got done however it got done. Basically, the clutch flex hose had to be installed in a pretty tight "S" shape, and there were no brackets to hold the hard line ends. Now that's fixed.
I don't have any before pics, but basically the firewall hard line end was floating, attached to a flex hose, slave cylinder hard line was also floating, and went upwards about 10", forcing flex hose to be in that "S" position.
The new flex hose is a Marling Crawler stainless steel braided line and it's only at a smooth 90 bend now. Both brackets I made out of 1.5" wide 1/8" thick steel flatstock bent on a vice and painted. Close clearances, but it doesn't touch or rub anything. Pedal feels a lot smoother.
Final advice: if you're going to do the 3.4 swap, get the V6 clutch hard line. It terminates much higher on the firewall and then you avoid this very difficult job.
Old 04-20-2020, 11:43 PM #74
4Reak Show's Avatar
4Reak Show's Avatar
My birthday was last week and my brother in law got me a cool gift: LED light kit specific for particular LEGO sets! In particular the Ghostbusters Ecto 1!
So you start with building the Ecto 1 which was a killer 508 piece set I had sitting in the box for like 2 years.
Complete with all the Ghostbusters and their gear
And then you add in the LEDs
Which are actual Lego pieces drilled out with lights installed and wired in to a battery pack. End result is killer! Flashing lights and super bright
Company is called Lightailing (like detailing, but with light). They makes tons of kits specific to particular sets. Very cool idea for adult nerds like me.
Old 04-25-2020, 11:15 PM #75
4Reak Show's Avatar
4Reak Show's Avatar
The due date for my second child is 4/28. Wife is super preggo and ready to pop any minute. So what I'm saying is that my projects are limited since I don't want to be tied up when the water breaks!
I ordered some patches to add to my headliner collection.
The America map is meant to be sharpie'd in with each state's visit.... So far I've only done a bunch in NorCal so it looks a little pathetic
Collection is going well though!
4runner , alright , conversion , cool , trans
Only 26th on this list? Nonsense! hikenbike General Discussions 11 11-26-2017 10:24 AM
This rookie needs your help regarding electrical nonsense netchemica 4th Gen T4Rs 3 10-28-2014 11:15 PM
2013 Los Angeles Auto Show and Tokyo Motor Show - 777 Photos trev0006 Off Topic 0 11-23-2013 06:35 PM
