Old 04-17-2021, 05:48 PM #91
4RunnerSafari's Avatar
4RunnerSafari 4RunnerSafari is offline
4RunnerSafari will become famous soon enough 4RunnerSafari will become famous soon enough
Looks like a nice roadtrip
Sent fra min WAS-LX1 via Tapatalk
4RunnerSafari is offline   Reply With QuoteReply With Quote
Old 05-01-2021, 11:12 AM #92
Voltan73's Avatar
Voltan73 Voltan73 is offline
Real Name: Jason
Voltan73 has a spectacular aura about Voltan73 has a spectacular aura about
Voltan73's Avatar
Real Name: Jason
Nice trip, always liked desert camping.
Happy belated as well. You have the same birthday as my wife.
Voltan73 is offline   Reply With QuoteReply With Quote
Old 05-01-2021, 05:56 PM #93
4Reak Show's Avatar
4Reak Show's Avatar
Yeah it was a trek. But awesome.
Small world on birthdays eh?! Easy to remember
Old 05-05-2021, 01:57 AM #94
4Reak Show's Avatar
4Reak Show's Avatar
I tend to always find something to do at night in the garage. As I was tinkering around last week our outdoor cat (who came with the house when we bought it 7 years ago) started making a real weird noise. Looked over and she had done a wonderful pest control job
That could have been the little bastard that chewed up my wife’s 5th gen injector wires a few months back. One less to worry about.
Old 05-05-2021, 09:49 AM #95
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
pest control is always great!
a few years ago a mouse was in our house and our 3 cats were not sure what to do since they have been inside their entire lives.
Shopvac worked wonders
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 05-06-2021, 01:23 AM #96
4Reak Show's Avatar
4Reak Show's Avatar
Yeah I hear that. On top of the outdoor only cat above, we have 4 indoor only; had 5 at our peak until one died.
Anyway, it’s funny how some lose the killer instinct. All but one of our indoor cats are stone cold lazy asses.
Old 06-29-2021, 02:27 AM #97
4Reak Show's Avatar
4Reak Show's Avatar
4Reak Show's build/use/nonsense
I’ve been dealing with a front end rattle for the entirety of my possession of the 4Reak. Metallic sound, most noticeable on washboard type roads, especially with a wall or cement guardrail next to me with the windows down to amplify the sound. Early on in ownership I replaced upper ball joints, lower ball joints, wheel bearings, inner tie rods, outer tie rods, steering idler arm, steering stabilizer, sway bar bushings, sway bar links, even CV axles and control arm bushings upper and lower to polyurethane. None of that made a single decibel of difference in the noise.
Some research in the last couple years lead me to the spindle bushings upon which the CV axle shafts ride. There is a special tool to pump grease into those cavities, a maintenance item I knew nothing about and have never performed. I’ve heard horror stories of replacing those bushings and since I’ve switched to AISIN manual hubs I saw even less reason to replace the bushings and instead fabricated my own special tool to just grease the piss out of them.
I procured a couple bearing nuts from a junkyard, the 54 or 55mm huge ass thin nuts that thread onto the spindle. I then welded one onto about a 4” long piece of 2” square tubing, capped the square and tapped a zurk fitting into the end. I packed my special tool full of grease and then finally undertook the task. Not too bad really.
I’ve heard this job can be done without removing the tires but with my hub covers it was too much of a pain. I opted to pull tires.
Here’s the special tool. You can find companies that make and sell them for like $80-100. Mine cost $2 for entry fee to the junkyard.
You remove the wheel, the hub assembly and the secondary bearing nut (the outer nut only) and install this tool in place of it. When pumping, it forces grease into the spindle bushings since it’s mostly sealed. The CV starts to move inboard once the packing process begins. Took 25-30 pumps of grease. So that cavity in question was BONE dry from 26 years of never being maintained.
Driver side went easy. Took about an hour all included from jacking up to torquing lug nuts. Passenger side went faster but with one hiccup: the locking ring that is single-splined onto the spindle was damaged. The ear that splines onto the spindle was no longer adequate and wouldn’t provide much locking. Luckily, when I had acquired the bearing nuts I referenced earlier, I also apparently took home a slightly used locking ring.
My motto is “it’s better to have it and not need it, than to need it and not have it.” So I must have brought that ring home subconsciously because I had no other reason to have the spare in one of my parts bins. Very stoked to have had it.
Anyway, I won’t be driving it again til later this week but I’m VERY confident that 17 year noise I’ve been chasing will be gone. CV axle play is night and day different. Prior it would wiggle in all 3 dimensions and it felt very metallic and similar to the noise. Now it’s TIGHT. Zero play in any direction.
If anyone in the area ever wants to borrow my special spindle bushings grease tool you’re welcome to it. Save some money and have a beer with me and get rid of an annoying ass noise.
@Voltan73 I’m looking at you....
Old 06-30-2021, 03:42 AM #98
That's a good idea, will deffently make one my self.
Before i assemble my steringknucles and cv's i add grease inside the bushing, but i guess i could add more to stable the cv more in center of the bushings.
Old 07-03-2021, 08:35 PM #99
4Reak Show's Avatar
4Reak Show's Avatar
Just wanted to update. After 17 years of dealing with that insanely annoying rattle noise it is confirmed totally 100% GONE! The truck seems to ride so much smoother and quieter but I think that’s in my head. Probably because I got used to that noise and it was just always background noise.
At any rate, anybody with a 1st or 2nd gen 4Runner or pickup and has a stupid front end metallic rattle, this greasing procedure solves it.
Old 07-06-2021, 04:23 PM #100
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
NUMBER 003 (REVISED)
DATE 04-27-90
MODEL RN6/VN6, RNO/VN0,
RN1/VN1, RN3/VN3 Better badder bushings...
Or just ditch the Brass bushings for T100 bearing
SaulG is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 11:51 PM #101
4Reak Show's Avatar
4Reak Show's Avatar
DATE 04-27-90
So I’ve heard about the bearing option. But I’ve also heard if they get water intrusion they are far less forgiving than just regreasing a bushing.
At any rate, with manual hubs those bushings should only see wear during 4wd. And with how little I’m currently off-roading, it will be centuries before it’s an issue again.
4runner , alright , conversion , cool , trans
Only 26th on this list? Nonsense! hikenbike General Discussions 11 11-26-2017 10:24 AM
2013 Los Angeles Auto Show and Tokyo Motor Show - 777 Photos trev0006 Off Topic 0 11-23-2013 06:35 PM
