05-20-2019, 08:39 AM
Real Name: Jason
Real Name: Jason
2nd Gen rear sag fix???????
I have the original rear shocks and springs from my 2018 Off Road, and I am wondering if these will fit on the 95 rear setup. I do know the 95 currently has stock equipment and the shocks have a Toyota part number that is a couple of digits off from the 18 shocks (I don't have the numbers with me at the moment).
I did find a couple of posts on other forums that mentioned using FJ springs and shocks and that is was possible. After looking at the setup on the 95 and comparing to the 18 equipment, the shocks look like they should be plug and play, however, the springs from the 18 look considerably taller.
Does anyone know if this swap will work? Has anyone tried this yet?
Thanks in advance.......
05-21-2019, 01:20 PM
Moderator
Real Name: The Chosen One
Moderator
Be the first to try it and let us know how it goes.
'89 4Runner SR5 - stock
05-23-2019, 09:46 AM
definitely try it and see!
I know things like this work in the Jeep world (Rubicon monotubes on older cherokees etc) but I haven't heard too much about interchangeability this except the FJ80 rear coils.
Stock 1993 3.0 V6 5SP 4.88s 31x10.5x15
05-24-2019, 08:49 AM
Real Name: Jason
Real Name: Jason
I guess I've been called out....which means I will be attempting the install this weekend. Will post updates as work progresses.....
05-25-2019, 05:17 PM
Moderator
Moderator
the entire Toyota world is counting on you, don't let us down.
05-26-2019, 02:07 PM
Yes for sure try this maybe it's a cheaper alternative to getting a lift kit
Sent from my Moto Z (2) using Tapatalk
05-31-2019, 02:40 PM
Anything?
06-01-2019, 07:08 PM
Guess this post died??
06-02-2019, 11:56 AM
Moog coils are cheap and easy to replace your stock springs with. They will eliminate sag, even give a tiny bit of lift.
06-10-2019, 06:55 AM
Real Name: Jason
Real Name: Jason
Sorry guys for the delay, finally got to the springs yesterday. The pics show that the springs are very similar, and appeared to be a plug and play option. However, when I installed the 2018 springs, I found that the bottom of the springs are different from stock. The bottom coil is wound tighter than the stock springs and therefore didn't fit into the spring perch on the axle. With the amount of fabrication that would be necessary, I am going with the Moog springs.
The shocks do bolt up in the factory location, but I may have some issues with the top isolator under the top nut. It appears that I may not have enough threads available to get the nut started. With that being said, I didn't proceed since I need to wait for the Moog springs.
06-11-2019, 06:38 PM
Moogs are a great call. Super cheap and I got a good inch over stock height.
06-13-2019, 03:04 PM
Real Name: Blair
Real Name: Blair
Anyone have the Moog part number? Not looking for a lift - just back to 'level' and not too harsh a ride if possible.
258K - Y2K/E - Clock still works
06-13-2019, 06:39 PM
https://www.amazon.com/Moog-CC255-Co.../dp/B000C55V52
06-14-2019, 08:47 AM
Real Name: Jason
Real Name: Jason
Just got mine in yesterday, will be installing this weekend and will post before and after pics next week.
06-18-2019, 07:16 AM
Real Name: Jason
Real Name: Jason
Looks a lot better, may end up going with a spacer to get a little higher in the back, but this will do for now. The shocks off the 18 off road did fit with no clearance issues related to the isolators.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
