Old 06-22-2019, 12:21 PM #1
hntz4x4 hntz4x4 is offline
hntz4x4 will become famous soon enough
SAS questions
I know probably going to get flamed for asking, but have done a ton of reading and can't get a clear answer.
We are doing a SAS on my son's 86 4runner. Plan is to use RUF with boomerang shackles, does the steering box need to be moved forward since these springs move the axle forward?
Where to place front hanger?
Where to cut holes for shackle mounts within the body mount?
Thanks,
Ryan
hntz4x4 is offline   Reply With QuoteReply With Quote
Old 06-22-2019, 02:46 PM #2
Ida4runner Ida4runner is offline
Ida4runner will become famous soon enough
hi,not sure I understand your question?
I used a front weld on spring hanger from trail gear and that required me to move my steering box forward so that i didn't have clearance issues with the cross over steering that you have to use when doing sas.
Are you using boomerang shackles up front, never heard of that?
Ida4runner is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 05:39 PM #3
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
Yes, you will need to move the steering box forward.
Most of the major Toy offroad shops that sell SAS kits have a template to help you locate the shackle mount. It duplicates the location on 84-85s with stock SFA.
Be advised that the stock rear packs may not be adequate and need an additional leaf or 2.
I built custom packs from my rears and leafs from 2WD rear packs, a front hanger that moves the axle 2" forward in addition to the 1" forward RUF provides.
Also using Budbuilts banana shackles (which I think you mean by boomerang shackles).
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 05:42 PM #4
fourwd1's Avatar
Moderator
Moderator
fourwd1's Avatar
BTW, the holes for the rear shackle mount are in the frame, not a "body mount", as in the last sentence in your post.
Old 06-24-2019, 11:02 PM #5
Brownfaux Brownfaux is offline
Brownfaux will become famous soon enough
Is the steering box relocation due to the length of the RUF springs?
I left mine where it was and all seems well. I did Trail Gear HD up front though.
Brownfaux is offline   Reply With QuoteReply With Quote
Old 06-25-2019, 01:14 PM #6
fourwd1's Avatar
Moderator
Moderator
fourwd1's Avatar
Yes, also due to the crossover steering.
Old 06-25-2019, 05:31 PM #7
Ya I know the shackle holes are through the frame, but people position them differently using that template within that body mount area.
Old 06-25-2019, 05:33 PM #8
Yes, but I think now he is going to leave the steering box where it is and go with different springs. Possibly ones from Davez Off Road.
Old 06-25-2019, 10:24 PM #9
I would advise moving the frame holes forward a bit based on where your front hanger is going to be. I cut mine before I realized my front hanger was all wrong. Had to move the front hanger back quite a bit and my shackle angle is crap, although with some use it has gotten better.
Old 06-26-2019, 04:45 PM #10
After talking to a couple guys that have done this, they suggested to cut the shackle holes in the center and then adjust the front hanger (which is only tacked on right now).
Old 07-01-2019, 08:05 PM #11
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
use the template included in the kit.
put the axle on the springs w/ tires and lower the weight of the truck onto the ground so you can check your shackle angle. If you use brand new springs there will be some settling of the springs but it is way easier to adjust a tacked front hanger than a fully welded hanger if you find your shackle angle is fubar.
This is some info on hanger placement from Scott at Addicted off road, came in handy on both my builds
Front Spring Hanger Placement: (when using longer than stock springs like Trail Gears)
Originally Posted by ScottyC View Post
He can't with the 3" springs. In fact, he needs to mount it 1/4" back of the front crossmember for a decent shackle angle and to have the tie rod and draglink clear each other on compression. Otherwise he'll be having to move the steering box forward.
I have all of these lifts down to a science at this point.
3" springs: 1/4" in back of the frame. Push the frame tube jig all the way forward in the body mount.
4" Springs 1/2" in front. Center the frame tube jib in the body mount
5" springs 3/4" in front. Center the frame tube jib in the body mount
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 07-04-2019, 06:02 PM #12
Thank you, good info.
Progress has stalled until my son can get the axle rebuilt.
box , forward , sas , springs , steering
2001 4runner tranny questions possible swap questions. Did search samario1984 3rd gen T4Rs 5 06-09-2017 01:27 PM
4th gen questions! Toyotafan03 4th Gen T4Rs 1 06-03-2015 09:40 AM
Considering HID's... Few questions first JayBe 5th gen T4Rs 2 06-26-2011 10:30 PM
2nd Gen. Questions clinte234 Classic T4Rs 15 08-16-2010 12:00 AM
Garmin iQue voice nav questions and Topo maps questions. Expat Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-11-2005 09:49 PM
