Old 06-27-2019, 09:50 AM #1
Alford87 Alford87 is offline
Real Name: Garrett Alford
Alford87 is on a distinguished road
2nd gen A/C and fan blower Electrical Problem
Alright so my fan blower and A/C are not working. When this initially happened I pulled the glove box out and checked the fuses and relays but couldn’t find the issue. So I just got my truck back from a mechanic and he has confirmed that the fan blower and a/c work but they are not getting power. He has replaced a relay and a resistor but this did not fix the issue. I believe he said he is losing power after the resistor. So any opinions would be great and if anyone by chance has the wiring diagram for this that would be very helpful.
Alford87 is offline   Reply With QuoteReply With Quote
Old 06-28-2019, 06:47 AM #2
Also I pulled up my fsm that’s on my phone but the air conditioning wiring section would not load, not sure what the issue is.
Old 06-30-2019, 08:53 AM #3
Figured someone on here would have a pdf of it. Any recommendations on where I can find it
Old 06-30-2019, 07:39 PM #4
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
check the blower motor resistor
having the blower motor resistor go out is very common on Toyota (multiple models/generations/years).
when i first got my 94 I had one speed. Pulled the dash apart, the fan switch was burned to a crisp. Replaced it with a donor switch I had, still ran like crap. Pulled the blower motor resistor,- mounted on the fire wall, right side under the blower motor..replaced it, have all fan speeds and life is good with the A/C and heat.
you can try going straight to the resistor but it is easier to pull the glove box out to get more room...start on the right side, remove the right side speaker housing and than you can see a few screws that hold the glove box in
Originally Posted by Dropzone View Post
based on what @joeynational mentioned here and some folks on yotatech said I went ahead and replaced the blower motor resistor today.
I'd like to have a talk with the genious at Toyota who decided to put a failure prone point in such a convience place (tucked under the blower unit on the right side)
I went ahead and pulled the glove box hoping for a little more room.
got it out after a few minutes and cussing, not the easiest thing to get out.
if you need to having a 7mm wrench helps on the back screw/bolt, you can get to the visible screw with a screwdriver or nut driver.
new one on the left, old one on the right..old one was slightly tarnished.
new one should offer a few years of good service
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 06-30-2019, 10:27 PM #5
I am pretty positive he replace the resistor and also the fan blower switch and neither helped. BUT I will verify this tomorrow. Thanks for the advice.
Old 07-01-2019, 07:52 PM #6
Dropzone's Avatar
Dropzone's Avatar
does the shop show it on your receipt? taking apart the dash to get to the fan switch (if you aren't familiar with the process) can be time consuming. How many hours did they charge you for replacing the dash and blower resistor?
Asking more out of curiosity. Not really sure what else it could be.
Hope you get it figured out. Tracking down electrical gremlins can be a major pain, good luck
edit: just re-read your 1st post and it says they replaced a relay & the resistor. So it could still be your switch.
@503dropzone on IG
Old 07-02-2019, 07:40 AM #7
Just spoke with him. He changed the blower switch ( only had to take the face of the dash off not the dash board) , resistor and relay. Said that he wasn’t getting power to a control board that’s past the resistor.
a/c , blower , fan , issue , power
03 4runner blower problem Fred4runner 4th Gen T4Rs 9 01-30-2017 09:33 PM
Fan blower motor problem? Ilovesnow 4th Gen T4Rs 6 01-30-2017 08:46 PM
Odd blower/heater fan problem Bftfan 4th Gen T4Rs 0 02-10-2015 09:51 PM
Need help with blower problem! kagerer General Discussions 1 01-03-2011 09:34 PM
Another blower problem OrbeaRider 4th Gen T4Rs 6 12-15-2010 08:45 AM
