Old 07-24-2019, 07:23 PM #1
sweatybandit sweatybandit is offline
sweatybandit is on a distinguished road
Popping noise when turning wheel at low speeds
'85 1st Gen, 2.5" OME lift, high steer conversion, 33" tires, RCV front axle
When driving at low speeds, less than ~10mph, when the wheel is pointed straight and then turn I slightly such as if I'm in traffic, there's a loud pop. Steering feels tight and accurate but the noise is disconcerting.
The pop noise happens regardless if I turn left or right. My sense is that it occurs at high speeds too, just that I can't hear it due to road and wind noise.
Any ideas on what this could be? Thanks in advance!
sweatybandit is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 10:48 PM #2
OzSurf OzSurf is offline
OzSurf will become famous soon enough
I would start by checking all the ball joints followed by inspecting all steering related parts including steering shaft & box.
OzSurf is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 02:28 PM #3
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
i know you mentioned RCV axles but it almost sounds like a broken Birf.
You don't have you hubs locked by mistake?
have you put the front end up on jackstands and wiggled both sides?
could be wheel bearings, etc
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 04:23 PM #4
Thanks guys, great places for me to start.
I was thinking it could be a CV joint but haven't had the truck up in the air. Posted this as soon as the noise started to get some ideas.
I'll start here and see what I'm able to find out. Thanks!!!
Old 07-25-2019, 04:42 PM #5
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
to clarify does the noise only happen when you're turning, or does it do it when you're driving straight down the road? If it's only when turning another area I'd look at in addition to the above suggestions would be your body mounts. I had a popping noise in my offroad rig that only happened when I turned after coming to a complete stop, founds out after a lot of troubleshooting that the body mounts were toast..if you have one, try mounting a go-pro under rig see if you can isolate where the sound is coming from. good luck.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 12:36 AM #6
Madrid1214 Madrid1214 is offline
Madrid1214 is on a distinguished road
I had the same problem. Had some popping when turning. It sounded really bad. Found out it was the steering stops. It’s a little bolt that stops the wheels from oversteering. Originally I guess it had a little rubber piece that prevents the loud popping. But I read you can apply some heavy duty grease for the meantime. Not a permanent solution but will work for a month or two.
This place sells them on the web. Pretty cheap.
TOYOTA 4Runner/Pickup 4X4 OEM steering stop cap 45619-36010
If I’m mistaken, please someone correct me. Thanks.
Madrid1214 is offline   Reply With QuoteReply With Quote
Old 08-04-2019, 12:00 AM #7
swerks's Avatar
swerks swerks is offline
swerks is on a distinguished road
swerks's Avatar
Leaf springs shifting
2005 limited Dobinson suspension/ 86 Turbo SR5 4Runner, TEC T3 turbo,2.5 " exhaust, ARB suspension, Rustoleum paint (Money pit)
swerks is offline   Reply With QuoteReply With Quote
Old 09-06-2019, 01:27 PM #8
aubuchond aubuchond is offline
aubuchond is on a distinguished road
I always have a popping noise only when backing up and turning right. You think it could be the cv joints?
aubuchond is offline   Reply With QuoteReply With Quote
Old 09-06-2019, 01:43 PM #9
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Can you unlock/lock the hubs and drive? Noise still there? That should help figure out if its the RCV or not.
probably not turn stops on a solid axle, as they move with the axle.
Probably not a ball joint on a solid axle, as they use trunion bearings (which could be worth looking in to)
Mentioned the high steer, is it hitting on something as the arm swings?
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
noise , pop , speeds , turn , wheel
Front End Popping Noise When Turning Left? Gecko 5th gen T4Rs 30 02-17-2024 06:12 PM
Popping Noise with Jerking Steering Wheel m.trout Problems & Warranty Issues 2 04-19-2017 04:01 PM
Popping noise when turning Mantree Classic T4Rs 11 03-11-2015 06:53 PM
Trouble turning wheel to the right in parking lots and low speeds Panzerpatty 3rd gen T4Rs 1 03-08-2013 03:13 PM
