Old 08-19-2019, 07:35 PM #1
pinemind pinemind is offline
pinemind will become famous soon enough
Losing Coolant w/all new components - Bumpy Roads
Hey all,
So I've been enjoying driving now that my engine bay project is done. However, I noticed that sometimes, my coolant reservoir is dropping. I could see some coolant sprayed in the IACV/Throttle body/thermostat area (ie rats nest of tiny hoses) but can't find the source. Furthermore, I narrowed it down to only happening when I drive on bumpy roads (offroad, cobblestone). I drove 2 hours in 95 degree heat on smooth highways, no loss. 15 minutes total on city potholes and cobblestone, lost about a half inch in the overflow.
I replaced everything with OEM parts. All hoses, clamps, overflow tank, cap, lower metal hose, radiator. It wasn't leaking before so I'm stumped. Going to do a dye test but was curious if anyone else has ever seen this?
Sent from my SM-G930F using Tapatalk
pinemind is offline   Reply With QuoteReply With Quote
Old 08-26-2019, 06:08 PM #2
Figured I would reply as I fixed the issue. I went through and cranked down every single clamp, most of the ones were for the silicone radiator hoses as I wasn't used to how much I could clamp them down. I'm assuming my observation of bumpy roads causing the issues were due to the clamps not being tight and coolant splashing through when getting thrashed around. The larger leaks stopped but now I noticed coolant coming out of the weep hole for the water pump. So I've got a Saturday project coming up soon.
cobblestone , coolant , hoses , overflow , roads
Losing Coolant - No CEL kcdehart 4th Gen T4Rs 16 02-28-2017 11:50 AM
Leak + Losing Coolant Peakester 3rd gen T4Rs 31 10-09-2016 05:14 PM
Headlight (HIDs) turns off when I drive bumpy roads.Turn them off/on and they turn on Zackadeez 3rd gen T4Rs 10 12-19-2014 06:20 AM
Creeking noise while driving on bumpy roads luckatheirish 5th gen T4Rs 13 04-04-2013 03:25 AM
98 losing coolant. ApocalypseAdam Problems & Warranty Issues 1 04-30-2011 10:54 PM
Copyright © 2019
