Old 09-15-2019, 12:59 PM #1
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
1st Gen T4R DIY, Maintenance, Repair, and Modification Videos
Hey Dudes,
I started a thread like this in the 3rd Gen section of the forum and now that I have an 85 and I'm making videos from the work I'm doing on it, I decided it made sense to start a video library in the Classic section of the forum as well.
This thread is also open to anyone else who would like to post their DIY videos. I will keep a Table of Contents updated so it will be easier for people to find the video they are looking for.
TABLE OF CONTENTS
1) Solid Front Axle Service Part 1 & 2
https://www.toyota-4runner.org/3356053-post2.html
2) Driveshaft Repair - Spline and Slip Assembly Replacement
https://www.toyota-4runner.org/3356064-post3.html
3) Toyota 22RE Tune-up
https://www.toyota-4runner.org/3373216-post5.html
4) Driveshaft Repair - Slip Yoke Grease Plug Has Fallen Out
https://www.toyota-4runner.org/3373825-post6.html
5) Toyota 22RE Cold Start Diagnosis and Fix
https://www.toyota-4runner.org/3377335-post7.html
6) Toyota 22RE Coolant Temperature Sensor Replacement
https://www.toyota-4runner.org/3410431-post14.html
Old 09-15-2019, 01:03 PM #2
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If you wanted to know how to service your solid front axle or replace a broken part somewhere in the assembly, this video series will show you how to get it done. We also show how to upgrade your knuckle (trunion) bearings with a Marlin Crawler 25mm knuckle bearing/pin upgrade kit.
Old 09-15-2019, 01:42 PM #3
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I noticed my front driveshaft had a bad u-joint, knew I could fix that, but there was also gross play in the splines which I knew I couldn't fix. Brought it to a driveshaft shop local to me in San Jose, California and got a heavy duty Trail Gear slip and spline assembly welded on and then rebalanced. If you find you're in the same situation, this might be an option for you as well instead of replacing the whole driveshaft.
Old 09-19-2019, 06:08 PM #4
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Nice! Thanks for sharing. IT makes tasks less daunting when we see fellow hobbyists do it and succeed.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 09:37 AM #5
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Toyota 22RE Tune-Up
Here's a video showing you how to perform a tune-up on a 22RE motor.
Old 10-18-2019, 08:57 AM #6
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Driveshaft Repair - Slip yoke grease plug has fallen out
This video discusses a problem you might encounter with one of your driveshafts and how you can fix it.
Old 10-24-2019, 02:28 PM #7
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If you're having a cold start issue with your 22RE motor, this video will share with you a couple possibilities what the problem is and how to fix it.
Old 11-02-2019, 04:24 PM #8
oken_e oken_e is offline
oken_e is on a distinguished road
Thanks so much for posting this. I just bought a 1986 4Runner from a neglectful owner that I'll be needing to sink some man-hours into.
I found out after taking it to the car wash that the o-ring on my distributor cap is totally rotten. I noticed in the video you were able to salvage yours—but do you by chance have a part no. for that o-ring or a lead on where they can be bought? I tried a couple of parts stores in town with no luck.
oken_e is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 01:34 AM #9
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I don't have a part number for that o-ring, but if it were me, I'd just visit my local Toyota dealer and pick one up. That o-ring can't cost that much money even at the dealership.
Old 11-06-2019, 07:57 PM #10
Folsom4Rnr's Avatar
Folsom4Rnr Folsom4Rnr is offline
Real Name: Brian
Folsom4Rnr will become famous soon enough
Folsom4Rnr's Avatar
Real Name: Brian
Super happy to run across this thread. Picked up a SAS'd 89 earlier this year and have been (very slowly) getting to know her and am sure this will help. Thanks for posting.
2006 Limited V8 in Titanium Metallic
Build and misc. adventure thread
Folsom4Rnr is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 01:28 AM #11
RAD4Runner's Avatar
RAD4Runner's Avatar
... do you by chance have a part no. for that o-ring or a lead on where they can be bought? I tried a couple of parts stores in town with no luck.
Originally Posted by mtbtim View Post
..That o-ring can't cost that much money even at the dealership.
YUP, inexpensive. I got Code 1081027 Distributor Cap O Ring 22R, for $3.49 from LC Engineering.
mtbtim,
Thank you very much, Sir, for sharing your knowledge and experience.
Old 12-05-2019, 06:56 PM #12
pinemind pinemind is offline
pinemind will become famous soon enough
22RE Cylinder Head Removal
So I stumbled upon this. Very informative and live end to end. Most head gasket/timing chain videos are old, grainy, or incomplete. Removes the head in a little over an hour
https://www.youtube.com/watch?v=O-AQWI1J9Ms
pinemind is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 06:01 PM #13
Thanks for the tip—I overlooked the most obvious solution. It was no problem getting that part from Toyota. Here's what was left of the old o-ring when I replaced it:
IMG-3841
Old 12-17-2019, 12:47 AM #14
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Hey Dudes,
If you found that your Engine Temperature Gauge isn't reading correctly or not at all, it may be because your coolant temp sensor has gone bad. In this video, I show you how to replace this sensor.
Old 12-18-2019, 02:30 AM #15
Cali 4runner Cali 4runner is offline
Cali 4runner is on a distinguished road
Nice vid. I read on yotatech that there are screws that come loose behind the temp gauge due to temperature fluctuations over the years. There is no longer good contact on the temp sensor and with no resistance on the gauge it immediately goes to the middle when powered.
Cali 4runner is offline   Reply With QuoteReply With Quote
forum , gen , section , table , videos
3rd Gen T4R DIY Maintenance, Repair and Modification Videos mtbtim 3rd gen T4Rs 1166 04-17-2024 12:40 PM
SURF RUNNER 2.0 Build, Maintenance & Modification: 2001 Stellar Blue Limited 4WD SURF RUNNER 3rd gen T4Rs 41 10-27-2020 10:01 AM
Good tech / Maintenance videos bob3dsf General Discussions 0 04-07-2016 03:52 PM
Pinstripe repair and fender maintenance on a TE? roadracer30 5th gen T4Rs 5 03-11-2013 07:16 PM
FREE repair/maintenance from AllData Mike the Wino Maintenance/Detailing 0 10-02-2008 10:58 AM
