Old 09-18-2019, 03:06 PM #1
PowellSixO's Avatar
PowellSixO PowellSixO is offline
PowellSixO is on a distinguished road
PowellSixO's Avatar
I need some serious help please! 3vze chattering at idle. WTH!!
I just got done dumping way way way too much $$$ in this turd bucket. And out of no where, it started running rough, and doing this weird chattering deal at idle. Any ideas or help please. I'm about to put a road flare in the back seat, with a full tank of gas. It ran great for a few weeks, then started having transmission shifting issues, so I had the solenoids replaced and a fluid flush. That did not fix the transmission. The transmission shop ended up putting a tps sensor in, which did fix the shifting issues. It ran great for a day then started ticking when driving. I haven't driven it more than a few hundred feet since the ticking starting. Now at idle it ticks as you can hear in this video, and the throttle body chatters. I tore both valve covers off to check valve clearances, thinking it was a valve train issue. All the clearances were perfect. What the hell? Haha.
YouTube
Recently done:
Heads rebuilt
Valves shimmed
Water pump
Timing set
AC compressor
Power steering pump
Head gaskets
Injectors
Knock Sensor
Rotor Cap Wires and Plugs
$2k worth of front suspension parts
Tires
Brakes
Transmission solenoids and fluid flush
Radiator
Hoses
TPS sensor
Air filter
And a bunch of other stuff I am surely forgetting
1992 4runner Work In Progress
PowellSixO is offline   Reply With QuoteReply With Quote
Old 09-18-2019, 05:32 PM #2
PowellSixO's Avatar
PowellSixO's Avatar
Could this be rod knock possibly?
Old 09-19-2019, 09:05 AM #3
PowellSixO's Avatar
PowellSixO's Avatar
I'm going to do a compression test on it this weekend. I'm starting to think I have a burnt valve. I guess I should have gone with a pair of new heads, instead of having the old ones rebuilt.
Old 09-19-2019, 10:09 AM #4
PowellSixO's Avatar
PowellSixO's Avatar
The reason I'm suspecting a burnt valve, is because of the throttle body chatter. Something is possibly pressurizing the intake. Which leads me to believe an intake valve. When I had the heads rebuilt, they only replaced one valve. The one they replaced is the intake valve on cylinder number 1. Using a stethoscope, I have tracked the noise down to the valve train on cylinder number one. Yay. I'll let you guys know.
Old 10-01-2019, 11:42 AM #5
ivbyiv ivbyiv is offline
ivbyiv is on a distinguished road
Any updates?
1994 4Runner SR5 Project truck
2000 ES300 daily beater
ivbyiv is offline   Reply With QuoteReply With Quote
Old 10-01-2019, 04:52 PM #6
Jimmy Two Dogs's Avatar
Jimmy Two Dogs Jimmy Two Dogs is offline
Jimmy Two Dogs is on a distinguished road
I'd love to see some photos of the "turd bucket".
Jimmy Two Dogs is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 05:59 PM #7
PowellSixO's Avatar
PowellSixO's Avatar
No updates on the Yota yet. Been busy. Going to try and get in there this weekend.
Old 10-30-2019, 12:33 AM #8
Clockworkmotors714 Clockworkmotors714 is offline
Clockworkmotors714 is on a distinguished road
Does not sound like a rod knock. Sounds like your standard valve train chatter. Can you record a video of the noise when you rev up the engine.
A lot of people are not familiar the type of shims required to adjust the lash on these engines. I’ve dealt with plenty of 3vzes that have been “repaired incorrectly”.
When I bought my 4Runner it always had a valve train tick and lacked power. When I rebuilt it and went through the cylinder heads, the lash was wayyyyyy off. I was surprised it could even run with the amount of lash it had.
Ask him how he adjusted the valve lash.
Also to determine a burnt valve you can perform a cylinder head leak down test. If you are unfamiliar with this. YouTube it and you’ll find a break down of what to do and how to verify a burnt valve concern.
Clockworkmotors714 is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 02:27 PM #9
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Did you check for check engine codes? Even if the light isnt on their may be a code.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 03:59 PM #10
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
I agree, doesn't sound like a rod knock - too "light" of a sound for that. Don't rule out an exhaust leak at the manifold. I've had those sound like something mechanically ticking, but it's the hot gases popping out of a small leak.
Get a piece of 3 foot hose and do some listening. Keep it and your hands away from the fan belt.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 02:15 PM #11
I would say pull a valve cover off, but they are a nightmare on these engines...
idle , sensor , started , transmission , valve
Idle problem on 3vze hargee Maintenance/Detailing 10 02-01-2023 08:09 PM
3vze--idle, timing, mixture issues Blamalam Classic T4Rs 3 09-25-2019 08:15 PM
3VZE High Idle mjquillici Classic T4Rs 6 03-02-2014 01:09 AM
HELP!!! 93 3vze won't start, when did start it didn't idle zed Classic T4Rs 9 02-28-2011 11:16 PM
3VZE idle fluctuating while in gear desertrunner88 Classic T4Rs 4 09-05-2010 06:17 AM
