Old 10-04-2019, 01:11 AM #1
Elitepass010 Elitepass010 is offline
Real Name: Daniel
Elitepass010 is on a distinguished road
Real Name: Daniel
1984 4runner 7.3 idi
Would like ideas and comments on possibly stuffing a ford 7.3L idi diesel into 84. Thinking zf5 speed with a double np203/bw1350 and 1 ton fords front and rear on custom frame. 7.3 also already has a bank's turbo installed
Elitepass010 is offline   Reply With QuoteReply With Quote
Old 10-04-2019, 01:18 AM #2
Real Name: Daniel
Real Name: Daniel
Did consider a sb 350....... but that's not original enough for me
Old 10-04-2019, 08:15 AM #3
TheLincolnGreen TheLincolnGreen is online now
TheLincolnGreen is on a distinguished road
MY GARAGE
MY GARAGE
I don't think I would want to add 500lbs to the front. That would have to throw off the balance of the 4runner.
TheLincolnGreen is online now   Reply With QuoteReply With Quote
Old 10-04-2019, 10:09 AM #4
Real Name: Daniel
Real Name: Daniel
Wish the motor only weight 500lbs... balance would not increase in front.... weight of extra transfer case would add another 120 in the center. 7.3 weighs 920lbs dry 1015 lbs wet, I'm more worried about how to add more weight to rear to keep traction
Old 10-04-2019, 10:21 AM #5
Real Name: Daniel
Real Name: Daniel
My last dyno of engine and trans combo with 4.10 gears and 37 tires was 225 hp @ rw and 590 tq @ re and that was under a 8k lb truck
Old 10-05-2019, 09:34 AM #6
Real Name: Daniel
Real Name: Daniel
Bumb
Old 10-06-2019, 02:32 PM #7
Redthies's Avatar
Redthies Redthies is offline
Redthies is on a distinguished road
Redthies's Avatar
Sounds like it would be really loud! But seriously, you don’t need to worry about balance etc if you’re doing a custom frame. Just put things where you need them to balance it out. You’d basically be building a truggy and putting the 4Runner body on it. Have you measured the engine for clearances under the T4R hood? 7.3s are, as you know, BIG engines.
Do you have the 84 already? Is it in good shape? If you’re going to do custom everything, why not sell the solid axle truck to someone who will keep it closer to stock, and hack up a cheap ifs rig?
Personally, I think it’s a waste of time type project, but I don’t have any time to waste, so what do I know?
Ď99 UZJ 100 factory locker with OME and ST Maxxs
Ď89 VN60 with OME and BFGs
Redthies is offline   Reply With QuoteReply With Quote
Old 10-06-2019, 05:22 PM #8
Real Name: Daniel
Real Name: Daniel
Originally Posted by Redthies View Post
Sounds like it would be really loud! But seriously, you donít need to worry about balance etc if youíre doing a custom frame. Just put things where you need them to balance it out. Youíd basically be building a truggy and putting the 4Runner body on it. Have you measured the engine for clearances under the T4R hood? 7.3s are, as you know, BIG engines.
Do you have the 84 already? Is it in good shape? If youíre going to do custom everything, why not sell the solid axle truck to someone who will keep it closer to stock, and hack up a cheap ifs rig?
Personally, I think itís a waste of time type project, but I donít have any time to waste, so what do I know?
Personally I think throwing a bunch of bolt on's at a vehicle is a waste of time. I am a fabricator so naturally I like to take what every one thinks is crazy and turn it into a beautiful rig. Like taking a 68 mustang and turning it into a tractor pull truck. So anyways this sr5 only cost me 200, I'm gonna take the frame and every thing and turn it into a small buggy for my kids. The body I'm gonna stick over a big o engine. So Engine is way wider, height not worried about, inner fenders of body will have to cut out and reformed. And I'm thinking will probably move entire fire wall back 4inch plus refab and extend front fenders and hood 8 inch. Then last and final would be moving rear fender wells 22 inch (about) back and keeping all stock body lines
Old 10-13-2019, 08:44 PM #9
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone will become famous soon enough Dropzone will become famous soon enough
Dropzone's Avatar
body swap onto the ford frame, you are gonna need the axles anyway
1994 4Runner AKA: Project Recycle
@5034Runner on Instagram
Dropzone is offline   Reply With QuoteReply With Quote
Old Yesterday, 07:22 AM #10
ev13wt ev13wt is offline
ev13wt is on a distinguished road
^^ what he said.
That engine will need a new frame, drivetrain, transmissions, drivelines.
It's a minitruck.
It makes zero sense.
If want to do something cool, put a tesla into it.
ev13wt is offline   Reply With QuoteReply With Quote
Old Yesterday, 09:36 AM #11
Real Name: Daniel
Real Name: Daniel
Yeah I'm in between the frames... . Ford frame would be easier, custom frame more convenient for doulbe tri. 4link.
Was thinking of using the ford cross members and facing new main beams.
To (member) putting a bb454 in to a Honda civic makes no sense either. But it makes for one bad a** drag racer.
double , idi , np203/bw1350 , speed , ton
1984 4Runner JFrank General Discussions 8 05-03-2018 08:29 AM
Volcom's 1984 4Runner Volcom Classic T4Rs 29 10-17-2017 10:33 AM
1984 Orange 4runner? dta1984 Classic T4Rs 5 11-11-2015 07:36 PM
1984 crusty 4runner Big Perm Classic T4Rs 2 12-19-2004 10:49 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
