Old 10-09-2019, 07:32 PM #1
Soulprogression108's Avatar
Soulprogression108 Soulprogression108 is offline
Soulprogression108 is on a distinguished road
Does fuel octane matter when setting timing?
So I’ve been trying to borrow a timing light forever so i can see where my 94 runner with 22re manual trans is set. And I finally gave up asking everyone I know and just bought a used older style one off ebay. I could’ve bought one and returned it but don’t feel good doing that.
Anyway the truck has been pinging with regular unleaded but goes away with premium or an added octane booster. I’m guessing whoever replaced the distributor didn’t do the timing or it came out of spec.
Anyway my question is... if the truck advances the timing automatically for higher octane fuel should I run the factory recommended regular unleaded when I’m setting the timing?
Soulprogression108 is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 08:34 AM #2
ev13wt ev13wt is offline
ev13wt is on a distinguished road
22-RE
More important is that you are in "jumpered" mode (RPMs drop), your RPMs are correctly adjusted at the correct screw.
Set it to jumpered mode, adjust rpm (use a 15 USD laser rpm meter from amaz / bay)
Set timing.
Note: you can adjust it more advanced than 5°. 8, even 10° works fine.
Tidbit:
The R in our engines stands for "Low Compression (uses 87 and below octane fuel)"
Edit: whatever fuel you adjust it with, the engine will compensate for higher or lower octane. It's not a race engine.
ev13wt is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 01:21 PM #3
Talking
Thank You for the help. I’ve got it set now and the truck is operating better than ever!
I had to go low, retarded to around 2/3’ to stop it pinging with regular gas. I read this was a Service recommendation years back to help with operating issues and it worked for me.
It also finally stopped idling too high on cold starts. Which it was doing at 5’ Now it idles up to warm up like any other vehicle. Around 1100rpm or so instead of 1400-1500
Only minor issue is the low idle (500) on warm restarts. I.e. restarting engine after its been running. It’s done this since I had it. Made a separate thread to look for help.
Funny enough now that the ac idle up works if the ac is on when i restart it idles at 750
bought , i’m , octane , timing , truck
cold air draft on pass side no matter what setting the cc is set at:( xspsi6 3rd gen T4Rs 4 03-08-2015 12:57 AM
What Octane Fuel? BFEATHER2008 3rd gen T4Rs 18 10-02-2012 10:32 AM
Octane does not matter? FourRunner2005 Engines / Suspension / Wheels / Tires / Audio / Accessories 13 07-06-2007 04:02 PM
Ignition timing with 87 and 91 Octane Gas Iowa4Runner 4th Gen T4Rs 15 09-22-2005 01:42 PM
