22-RE
More important is that you are in "jumpered" mode (RPMs drop), your RPMs are correctly adjusted at the correct screw.
Set it to jumpered mode, adjust rpm (use a 15 USD laser rpm meter from amaz / bay)
Set timing.
Note: you can adjust it more advanced than 5°. 8, even 10° works fine.
Tidbit:
The R in our engines stands for "Low Compression (uses 87 and below octane fuel)"
Edit: whatever fuel you adjust it with, the engine will compensate for higher or lower octane. It's not a race engine.
