Old 10-13-2019, 11:33 AM #1
Jasonredwood's Avatar
Jasonredwood Jasonredwood is offline
Jasonredwood is on a distinguished road
1st gen 4runner rear seat belt question
I have a 85 4runner with a couple lap belts in the back but they aren’t very functional. From what I read they were a common dealer installed option.
Been reading up on installing shoulder belts but the small issue of the rear interior card is a solid piece.
Has anyone gone about similar modifications?
I’m thinking I could carefully trim a hole where needs be and add some edging trim of some sort.
1st gen 4runner rear seat belt question-11a4eb4a-4fd1-46b9-9869-b31313088210-jpg
Jason
1985 fj60
2006 4runner v8 4x4 sport
http://www.jasonredwoodart.com
Jasonredwood is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 07:20 AM #2
ev13wt ev13wt is offline
ev13wt is on a distinguished road
Pull the panel and see if the mounting locations are there. Should be!
Then all you need is new trim pieces.
Shoulder part simply bolts to the roll cage.
ev13wt is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 11:26 AM #3
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
I haven't done it myself, but apparently 2nd gen truck belts will bolt right into place on the rear.
check the roll bar, you'll see the thread spot up high on each side, that's for the shoulder belt.
supposedly its a direct bolt up.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 03:16 PM #4
Thanks! Gona check the pick n pull here soon
Jason
1985 fj60
Old 10-15-2019, 01:47 AM #5
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Yes, two mounting points on roll-bar. They're covered with plastic caps. Plug and play.
Outer lap mounts are just outboard of the seat bottoms. Lap belts mount to them.
Bolts are 7/16-20 thread or somewhere around that.
Someone on Yotatech or here said a Subaru shoulder-seatbelt fits. i used seatbelt and mechanism from Toyota pick up. Unfortunately, they're a little slack when unused but fit well when worn.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 06:24 AM #6
wallytoo's Avatar
wallytoo wallytoo is offline
wallytoo has a spectacular aura about wallytoo has a spectacular aura about
wallytoo's Avatar
mid- to late-90s subaru legacy belts work perfect. correct length, too.
member, new hampshire timberland owners association (NHTOA)
1987 4runner sr5, 22re, 5-speed
1988 4runner sr5, 3.0, auto (parts rig)
1987 4runner, sr5, 22re, 5-speed (#2)
wallytoo is offline   Reply With QuoteReply With Quote
4runner , belts , rear , solid , trim
rear seat belt issue/question fan of fanboys 3rd gen T4Rs 1 11-15-2017 12:38 PM
Center seat belt question tjaguilar 3rd gen T4Rs 8 07-03-2017 02:52 PM
Seat belt question Rifter 3rd gen T4Rs 2 03-24-2015 02:55 PM
Need help replacing rear seat belt, '96 4Runner Rainer-LB 3rd gen T4Rs 0 01-30-2015 10:30 PM
Seat belt question bolantej 3rd gen T4Rs 2 05-23-2012 01:49 AM
