Old 10-15-2019, 12:51 AM #1
HiluxSurfBC HiluxSurfBC is offline
HiluxSurfBC is on a distinguished road
Spring Installation for 2nd Gen (Hilux Surf)
Hey guys, i picked up an EMU 2" lift kit for my 91 Hilux Surf, and i am having some difficulties installing the new springs.
I've lowered the rear axle as far as my jackstands can go, and I have lifted the hitch as far up as i can. I made sure to disconnect the rear sway bar (I think that's what it's called) and there is a rear horizontal stabalizer bar i have also disconnected.
Even with using spring compressors i am having troubles.
A question i have, those upside down rubber triangle things that sit above the spring that has 2 little rubber balls on it. Does that entire thing come off? I have looked and i don't see any sort of nut/bolt holding it on, however with a decent amount of pressure i am unable to pry them out.
HiluxSurfBC is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 09:13 AM #2
When I looked before I couldn't find any sort of cover that would be covering up the bolts. When I'm back home I'll take another look and get back to you! Thanks for the help bud
Old 10-15-2019, 01:13 PM #3
RonJR RonJR is offline
Real Name: Ron
RonJR will become famous soon enough RonJR will become famous soon enough
Real Name: Ron
Generally I have to stick a bottle jack in between the axle and the frame to push the axle down enough to get the spring out. The various bushings seem to resist axle droop enough that you can't push it down adequately by hand.
Just really watch the brake lines to make sure you don't over extend them.
Also, it usually helps to raise the opposite side of the axle while you're pushing down on the side you're working on.
2006 Sport Edition, V8, 181K miles, 2.5/1.5 Daystar spacer lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 221K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
bar , hilux , rear , spring , surf
Hilux surf SilverRidgeRunner1 3rd gen T4Rs 40 08-14-2018 08:25 AM
Anybody want a Hilux Surf? IanB 3rd gen T4Rs 18 10-16-2014 02:23 PM
Anyone Own a Hilux Surf bia Edmonton / Calgary / Alberta 6 09-19-2013 09:10 PM
My new Hilux Surf 00HiluxSurfLTD 3rd gen T4Rs 9 08-21-2008 01:59 PM
Hilux Surf Bag - US? ATLRunner Engines / Suspension / Wheels / Tires / Audio / Accessories 9 12-24-2004 11:51 AM
Copyright © 2019
