Old 10-22-2019, 11:41 AM #1
Blind Cleric Blind Cleric is offline
Blind Cleric is on a distinguished road
radiator replacement
I have original radiator on my 1990 auto and am thinking it might be a good idea to replace, even though it's not leaking.
Anyone else running original radiator, or have a suggestion for replacement brand? Thanks.
Blind Cleric is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 09:00 AM #2
grande grande is offline
grande is on a distinguished road
About four years ago, the radiator in my '92 was developing pinhole leaks in the top tank. I had it replaced by a shop. The replacement radiator has plastic tanks. Unfortunately, I don't where the shop got it. But they were available about 4 years ago. Good luck.
grande is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 09:10 AM #3
Captsolo Captsolo is offline
Captsolo will become famous soon enough
plastic radiators
All radiators today are made with plastic. Some all Aluminum are here. https://www.amazon.com/s?k=4runner+r...b_sb_ss_i_1_16
Captsolo is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 01:10 PM #4
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Originally Posted by Blind Cleric View Post
... it might be a good idea to replace, even though it's not leaking...
Not leaking and not overheating? Why fix what's not broken?
If you must, I think CSF makes all-metal radiators.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 02:26 AM #5
Rockdawg84's Avatar
Rockdawg84 Rockdawg84 is offline
Real Name: Sam
Rockdawg84 will become famous soon enough Rockdawg84 will become famous soon enough
Rockdawg84's Avatar
Real Name: Sam
Just installed this in my Runner. It has nice build quality.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
because I have a 1st gen I had to drop it down just a little bit but you should not have to do anything but bolt it in.
84 Crawler Rockdawg84s Pic build thread but mostly pics
94 Fzj80 family hauler - sold
98 SR5 supercharged 5speed on 35's, dual locked, dual cased Smokey build Thread
03 SR5 V8, 4x4, 2.5" Icon's with 35's -Sold The Wife's 03 Build Sold
Rockdawg84 is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 10:47 PM #6
BryanS BryanS is offline
BryanS is on a distinguished road
Amazon.com: Primecooling 3 Row All Aluminum Radiator for Toyota 4Runner Pickup SR5 DLX, 3.0L V6 Engine 1988-95: Automotive
The Al radiator is the way to go!
BryanS is offline   Reply With QuoteReply With Quote
Old 12-17-2019, 11:14 AM #7
Jimmy Two Dogs's Avatar
Jimmy Two Dogs Jimmy Two Dogs is offline
Jimmy Two Dogs is on a distinguished road
I'd been told that Moline made the best radiators...guaranteed for life or something like that.
So when I needed a new radiator for my '90 4Runner, I put in a Moline. Well, it wasn't all that long (a year or a bit more) before it failed. Rather than exercise the guarantee, I just had a Toyota dealer put in a new radiator. Don't know what kind, but it's still going strong years later.
Jimmy Two Dogs is offline   Reply With QuoteReply With Quote
Old 12-17-2019, 01:15 PM #8
warrpath4x4 warrpath4x4 is offline
Real Name: shawn
warrpath4x4 is on a distinguished road
Real Name: shawn
Not sure if yours is a 22RE or a 3.0 but i put an all aluminum V6 radiator with electric fan and shroud in my 22RE 4Runner. just had to redrill the 2 lower mounting holes.
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
Abraham Lincoln
warrpath4x4 is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 06:22 PM #9
RAD4Runner's Avatar
RAD4Runner's Avatar
V6 Radiator Into a 22R-E
Originally Posted by warrpath4x4 View Post
... i put an all aluminum V6 radiator with electric fan and shroud in my 22RE 4Runner. just had to redrill the 2 lower mounting holes.
I wonder if the V6 radiator would actually improve cooling on a 22RE,
What was the problem you had that made you change radiators, and did the V6 radiator significantly fix it?
I've heard that the OEM radiator for 3.0 also works.
Does anybody have first-hand experience with this?
Old 12-18-2019, 07:50 PM #10
Real Name: shawn
Real Name: shawn
the V6 radiators are a couple inches taller so there are more cooling fins. I didnt really have a problem, i had just gotten the 4Runner and was revamping a lot of stuff. i can tell you that the electric fan on a thermostat has not even kicked on yet (but it is winter also) and the heater still works good.
Abraham Lincoln
Old 12-27-2019, 12:19 AM #11
4RunnerSean 4RunnerSean is offline
4RunnerSean is on a distinguished road
I have a 1992. I did a bunch of research on re-core, plastic & aluminum, but eventually purchased an all aluminum. Here is what I purchased (assuming you have the V6):
Champion Cooling Systems CC50: All-Aluminum Radiator 1988-1995 Toyota Truck & 4Runner | JEGS
4RunnerSean is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 04:21 AM #12
stomper4x4 stomper4x4 is offline
stomper4x4 is on a distinguished road
I recently replaced the original in my 92 also and I'm glad I did. The radiatior shop tested it out and it was really bad. It was all brittle and not repairable. It all appeared to be fine in the truck but I just had a feeling that I should get it checked out. They can get rotten.
So the shop got me a brand new 4 core all copper radiator like the original. These 3.0's like to stay cool so I wasn't going to mess with one of those 1 or 2 core aluminum ones with the plastic tanks. I figure the original lasted this long, another one like it ought to go another 25 plus years.
Just replacing the radiator the rig is running cooler also. Go ahead and do it. Talk to a local shop and let them know you want a 4 core copper like original.
stomper4x4 is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 12:17 PM #13
Csmithbass Csmithbass is offline
Csmithbass is on a distinguished road
Original rad on a ‘95
Still running the original radiator in my ‘95...though I have seen specks of coppery/gold metal in the coolant reservoir.
We just blew out the head gasket and Hydrolocked 😬 so I was debating replacing it... any thoughts guys? I’ve been running green. Did not know about the green vs red thing, so I drained the rad and will be replacing with red rad fluid
Csmithbass is offline   Reply With QuoteReply With Quote
leaking , original , radiator , replace , replacement
How to radiator replacement Crashnrondo 3rd gen T4Rs 57 07-05-2018 01:14 AM
Radiator replacement - when? 4by4runr 4th Gen T4Rs 21 09-07-2016 11:40 PM
03 radiator replacement kirkg 4th Gen T4Rs 17 10-20-2014 07:55 PM
Radiator replacement ryani 3rd gen T4Rs 12 01-10-2010 11:00 PM
