11-23-2019, 12:12 AM
Real Name: Kevin
Real Name: Kevin
87 22RE A/C Clutch
Anyone have a good source for the a/c clutch? Mine is worn to the rivets.
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
11-23-2019, 02:05 AM
Subscribed.
Got symptoms (strange sound, etc), or did you just see it worn out?
My clutch grunts when engaging. I haven't looked very closely.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
11-23-2019, 05:14 PM
Real Name: Jason
Real Name: Jason
WorldPac. Got a Denso compressor/clutch assembly for my '88 for a fraction of what the Genuine Toyota part costs.
11-28-2019, 11:23 AM
Real Name: Kevin
Real Name: Kevin
Originally Posted by RAD4Runner
Subscribed.
Noisy and lots of what looked like brake dust in the front of the engine compartment. I removed it and it is worn to the point the rivets are being ground.
11-28-2019, 11:24 AM
Real Name: Kevin
Real Name: Kevin
Thanks, I'll check it out.
11-28-2019, 11:38 AM
Real Name: Kevin
Real Name: Kevin
Not that easy to find available parts. Do you have an account?
11-29-2019, 03:29 PM
Real Name: Jason
Real Name: Jason
WorldPac is a wholesaler. Got any friends that work at a dealership? Doesn't have to be a Toyota dealer. Or any friends at an independent shop? They could buy from WorldPac as well...
