Old 11-26-2019, 09:49 AM #1
sdb999 sdb999 is offline
sdb999 is on a distinguished road
Rear brake bleeding issue
A while back I replaced both brake lines running to the rear LSPV. I had no braking issues prior to this, one line had corroded through and began leaking so I replaced both along with the fuel line.
I bled the master, all wheel cylinders/calipers and LSPV, in that order multiple times. After the better part of a quart of brake fluid I still get air from the rear brake cylinders...and I mean tons of air...it looks like aerated clean fluid. The front calipers and LSPV produce a steady stream of bubble free clear fluid. I can drive the truck but of course the braking is very poor and spongy.
Not sure it matters but I work solo so I always use a pressure bleeder attached to the master cylinder. With 10-15 psi behind the reservoir I can't sort out how air can get in to the system, when I have a leak is see it immediately as fluid exits. Where/how is the air getting in this system? And only the rear cylinders? LSPV? Master? I'm at a loss.
Thanks, S.
sdb999 is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 08:52 PM #2
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone will become famous soon enough Dropzone will become famous soon enough
Dropzone's Avatar
did you start bleeding them from the back and working your way forward?
I think the order is left rear, right rear LSPV etc..if you did it in some random order you are gonna get air in the lines.
i have always had someone pump the pedal for me. Never had an issue with bleeding brakes doing it this way in almost 35 years of working on miscellaneous junk cars i have owned.
1994 4Runner AKA: Project Recycle
@503dropzone on Instagram
Dropzone is offline   Reply With QuoteReply With Quote
Old 12-02-2019, 06:47 PM #3
Yep, thatís the order except lspv last as itís the highest point in the system. I tried the rear to front variant as well with no change. Itís either the lspv or master at this point. Iím going to pull the lspv and try again. If that works Iíll install a manual proportioning valve and be done with it. Thanks.
air , brake , fluid , lspv , rear
Rear brake lines exploded while bleeding brake fluid benztech82 4th Gen T4Rs 3 08-11-2017 08:16 PM
Brake bleeding after tundra brake upgrade Cadaverous 3rd gen T4Rs 25 08-11-2017 12:02 AM
Brake Fluid - Brake Bleeding RiFF RaFF Classic T4Rs 5 11-15-2013 09:23 AM
brake bleeding issue robstibz 3rd gen T4Rs 7 08-18-2007 07:03 PM
Brake Bleeding - Small Issue bmay Maintenance/Detailing 5 07-25-2006 07:01 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
