Old 12-09-2019, 12:59 PM #1
theking11863's Avatar
theking11863 theking11863 is offline
Real Name: Kyle
theking11863 is on a distinguished road
Real Name: Kyle
22re limp mode
Hey guys, been awhile since I’ve posted. Recently I acquired a 91 DLX Pickup 22re 5speed and the thing has been running great for the most part up until last weak. I noticed that once its been running for a little while the thing just will not go! At idle and below like 2000 rpms (I don’t have the tach so I’m guessing on the rpms) it runs and revs perfectly fine, then when it passes that magic number is just stops. Its not a misfire. It sounds the same as when it hits the rev limiter but at 2500rpms.
So my guess is that for whatever reason the engine is shutting off the fuel or spark when it hits those conditions. Someone suggested to me this morning that maybe its the temp sensor that runs to the computer because it runs perfectly fine when it first starts up until it reaches operating temperature. Anyone have any thoughts on whether or not this is true? Need to get this fixed asap as its my only set of wheels in the snow
1990 Toyota 4Runner SR5 V6 5 Speed Manual 4x4 263k miles
1995 Toyota 4Runner SR5 V6 5 Speed Manual 4x4 (Sold @ 225k)
1996 Toyota 4Runner SR5 V6 (Totaled @ 317k miles)
1991 Toyota Pickup DLX 22re 5 Speed Manual 4x4 206k miles
theking11863 is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 12:24 AM #2
kc15842 kc15842 is offline
Real Name: Kevin
kc15842 will become famous soon enough
Real Name: Kevin
Have you checked for a code. I'll bet a 52.
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
kc15842 is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 01:39 PM #3
Real Name: Kyle
Real Name: Kyle
I checked. No codes. I let it run for a minute then disconnected the temp sensor and it seemed to run fine during my test so I’m thinking it is the sensor. Just remembered I have a brand new toyota sensor in my 4runner that isn’t being used so I think I’m going to try and put it in the pickup and see if the problem goes away.
If not I’m thinking maybe tps since on one of my last drives it started to wake up a bit when I floored it. If its not talking to the computer I’d imagine it wouldn’t allow the engine to go unless it could really tell the throttle body was open. Honestly I’m grasping at straws on that one but the 4runner has a good sensor so its easy enough to remove and check. Something’s gotta work eventually right?
Old 12-12-2019, 08:57 PM #4
zidaro's Avatar
zidaro zidaro is offline
zidaro is on a distinguished road
zidaro's Avatar
change your fuel filter recently?
Couple Yotas
Iluv4xToys!
zidaro is offline   Reply With QuoteReply With Quote
fine , hits , perfectly , rpms , runs
3rd gen Limp mode? MandAtaco 3rd gen T4Rs 7 03-07-2023 12:15 AM
Disable limp mode? mark.stevens.399 4th Gen T4Rs 2 03-17-2018 12:02 PM
2006 V8 4Runner limp mode HELP!!!! HanIsa97 Problems & Warranty Issues 0 08-23-2017 08:07 PM
Limp Mode/Carmax is awesome Morphyne Lexus GX470/460 1 10-08-2015 09:17 AM
Trans in limp mode '92 T4R luther91 3rd gen T4Rs 2 06-15-2015 07:14 PM
