Man one of my favorite 1st gen's is gone?!?!?
I get the whole long time with one project, one reason I moved on from my Trekker after 10 years.
Looking forward to see how your new build goes.
Was the 23 spline shaft in a T/C that ran a little low on gear oil? just asking because of the discoloration
Originally Posted by Volcom
Had to pull the t-cases apart to get the stock 21 spline input in the front reduction block out. Going behind an auto, it has to be upgraded to 23 spline.
21 vs 23 input by VolcomCO
Little size comparison
which adapter did you use? i am using an inchworm I got from low range right before they were bought out by trail-gear and am using 21 spline stuff...because I am cheap and lazy and it came with a 23 to 21 spline adapter to use behind the A340H
