Old 12-19-2019, 05:55 PM #1
4restGump 4restGump is offline
4restGump is on a distinguished road
3.4 swap into 3.0 4runner
Hello all
I’m looking to buy a 1988 4runner with a 3.0 V6 engine. The truck itself is very clean for the salt belt region where I’m in, the problem is the engine. It has some nasty misfire and stalling in gear.
So I was just wondering how hard would it be to swap a 3.4 engine into it? I had Tacoma and 4runner with the 3.4 and very familiar with it. Any pointer on the subject is greatly appreciated.
4restGump is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 11:39 PM #2
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
In the scheme of Harry Homeowner DIY mechanicals? Very hard. In the scheme of engine swaps? Not hard at all. It's all relative. If you're going to do it right, it's definitely a time-consuming undertaking. There's an entire forum section devoted to the subject over at Yotatech. Your 3.0 might just need a valve job anyway.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 12-20-2019, 01:10 AM #3
4Reak Show's Avatar
4Reak Show's Avatar
I did it to mine about 10 yrs ago. Couldn't recommend it enough. IF you're up for the challenge and cost commitment. Took me 2 yrs of prep and $5,000. Of course I was 22 and living at home at didn't make a whole lot of money so it was save save save, buy one piece. Save save save, buy one piece. Over and over until it was all ready. Then I did the entire swap in about 4 days at the shop I worked at using power tools and lift etc.
Check out off road solutions (.com?) anyhow there is a wealth of knowledge. But just be prepared, there's a lot of little things to tackle.
It took me years to finally get it to 100% perfect working order. If you include stuff like cruise control and little odds and ends. Even to this day, my heater valve control doesn't quite exactly go to full cold by 1/8" because I relocated the heater valve a bit and the cable binds slightly when I push it that direction. Open the hood and manually move it 1 millionth of an inch the lever inside is perfect. Little stuff like that. It adds up to time time and more time depending on your OCD.
But I'll tell you what: you get it supercharged and start laying into it going up a mountain pass and it makes all those hours worth it. Turns it into a new vehicle.
Old 12-29-2019, 01:17 PM #4
Pappy Jon Pappy Jon is offline
Pappy Jon is on a distinguished road
Been done. A whole lot. Two sources to get you started. These two companies are the go to for 5VZ-FE and 3RZ-FE swaps.
Toy Only Swaps | Toyota 3.4 Swap Parts | 5vze Engine Swap Specialists
Toyota Truck Specialists - Off Road Solutions
Pappy Jon is offline   Reply With QuoteReply With Quote
4runner , engine , i’m , swap , wondering
Bad_Vision's 1985 Toyota 4RUNNER TDI Swap (Completed swap) Bad_Vision Classic T4Rs 211 10-06-2019 10:56 PM
Swap 4Runner for LC DCOURTS1984 5th gen T4Rs 15 07-03-2018 05:43 PM
86 4runner 5.3 swap lsx angle Classic T4Rs 11 03-08-2015 09:53 PM
95 3.0 into 90 4runner swap. runnerDan Classic T4Rs 3 11-04-2014 05:24 PM
Swap A V8 Into A 01 4runner?? Hyper_r_boy Engines / Suspension / Wheels / Tires / Audio / Accessories 8 05-23-2005 09:54 AM
