Old 12-28-2019, 08:33 PM #1
joeynational's Avatar
joeynational joeynational is offline
joeynational will become famous soon enough
Seam sealer?
I removed my front fenders while doing my 5vz swap. I noticed they have seam sealer. Would it be a bad idea to put the fenders back on without a new bead of sealer? I'm also assuming if i put new sealer i should probably remove all the old stuff right?
Seam sealer?-img_4247-jpg
My build thread;
https://www.toyota-4runner.org/class...achillies.html
joeynational is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 10:03 PM #2
Cali 4runner Cali 4runner is offline
Cali 4runner is on a distinguished road
I have not worked with seam sealer, but I would scrape off the old stuff before putting on new.
Cali 4runner is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 11:22 PM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Transtar Black Seam Sealer
Use this stuff right here. Use your Butane torch to heat up the old sealer, get to about 3-400 degrees and it will scrape right off. Clean it up with a scotch brite wheel to get back to bare metal. This stuff just requires a caulk gun to apply.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 10:24 PM #4
[QUOTE=shadow247;3415497]Transtar Black Seam Sealer
Use this stuff right here. Use your Butane torch to heat up the old sealer, get to about 3-400 degrees and it will scrape right off. Clean it up with a scotch brite wheel to get back to bare metal. This stuff just requires a caulk gun to apply.[/QUOT
Thanks! I was actually looking at this stuff yesterday. I chipped off what i could with my scrapper and hammer then sanded the rest off with my buffer down to bare metal. I'll repaint this when i do my engine bay then put down a new bead
My build thread;
Old 12-29-2019, 10:27 PM #5
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
looks like butyl tape
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 09:52 PM #6
shadow247's Avatar
shadow247's Avatar
Butyl Tape would work in a pinch, but it's really only meant for bolt in side windows. It will get too hot in the engine bay and end up all runny. I've had to clean it up when it's 105 outside and the sheet metal is 120 degrees or more from sitting in the sun. It's gets runny and messy and would likely just dissolve completely from the extreme engine heat.
The 4Runner Show
Old 01-01-2020, 02:08 PM #7
Dropzone's Avatar
Dropzone's Avatar
that makes sense, my only experience with butyl tape was peeling off when I removed the top on my old 81 Toyota Trekker to covert it to a removeable top. Made a soft ball size glob of goo
@503dropzone on IG
fenders , put , remove , sealer , seam
Seam Sealer? STI_MECE 3rd gen T4Rs 10 09-18-2019 12:21 PM
Liftgate seam picture? Schrek 5th gen T4Rs 2 06-16-2018 02:42 PM
Recommendation for M Sealer OldSchool1959 Maintenance/Detailing 0 02-23-2014 04:54 PM
seam a bit pricey to you? Iroke17 Classic T4Rs 7 02-08-2012 07:04 PM
dose this seam like a good idea? Iroke17 Classic T4Rs 14 09-14-2011 10:39 AM
