A friend asked my what gear I was in and I said: 2nd low, 4th gear. He asked what gear over all, and I had no idea. So I mathed it out. The red is the "gear #"
This is for my r150 with 2.28/4.7 duals, but the pattern should be similar for most
So , 2nd low (4.7 case) 4th gear, is 10th gear overall.
I also did it out on my work bench for the Danger Runner with its w56 and stock duals. I only did one row for the 2.28, as both would have the same number.
Im going to type it up in Excel so I can print it and stick it in the visor. I dont know if this info is out there somewhere, but I couldnt find it.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
