Old 01-20-2020, 03:53 PM #1
ddnww's Avatar
ddnww ddnww is offline
ddnww is on a distinguished road
ddnww's Avatar
Info on rear end
Can someone with an 86-95 measure the width from back of drum to back of drum on other side for me please?
Also do these years models that had the thicker rear end on the v6/ turbo Toyota/ pickup/ 4runner have the same width as the 4 cyl rear end?
2007 Driftwood Pearl SR5 V6 4x4 /MB Wheels TKO 17x8.5 -6mm/ Hankook dynapro mt2 285/70/17 / bilstein 5100s -1.5 daystar rear spacer lift on moog fj coils / 1" Toytec body lift / ddm hids / interior leds / reverse light led / vsc - atrac disable mod / limo-30% tint/ rear diff breather mod / rola vortex roof rack / hanma 30" LED lightbar / kenwood ddx373bt w backup camera / ppi p900.4 / sundown sax1200d sa8d4v1.5 / diamond audio d6 comps / SPPC black halos
ddnww is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 05:09 PM #2
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
V6 & Turbo diffs have 4 spiders gears in the rear third
4 Cyl diffs have 2 spider gears.
I don't actually get what you mean thicker rear end..been messing with these POS's for 34 years
Below pulled from Pirate FAQ
Stock Toyota front axle measurements for comparison:
55.5" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, SA Hubs
58.25" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, IFS Hubs
63.5" wide, (set up for coil springs) 90-97 FJ80 and FZJ80 Landcruisers
'86-95 IFS front end is about 58.5" wide
'93-98 T100 IFS front end is about 65" wide
Toyota Rear Axle Widths:
55" wide, '79-85 4wd trucks/4runners - 6 Lug
58" wide, '86-95 4wd trucks/4runners - 6 Lug
56" wide, '79-95 2wd Trucks - 5 Lug
60.75" wide, '95.5-up Tacomas/4runners
66.75" wide, '93-98 T100 trucks
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 09:35 PM #3
ddnww's Avatar
ddnww's Avatar
Thank you, ok so the difference is 2 pinion vs 4 pinion on the 4cyl to 6 cyl rear ends.
I know the 86-95 is 58 inches wide at the flangeto flange aka wheel mounting surface, but I need the measurement from the back plate to back plate, I believe it should be about 50 inches.
Old 01-20-2020, 10:06 PM #4
Dropzone's Avatar
Dropzone's Avatar
2 and 4 spider gears..each diff only has one pinion gear.
@503dropzone on IG
back , drum , end , rear , width
I need rear info. b1g$t33m3r 3rd gen T4Rs 4 11-15-2014 12:40 AM
1999 SR5 4X4 rear diff info needed 99runnerSR5 General Discussions 2 07-29-2013 03:43 PM
rear glass swap info tv4184 3rd gen T4Rs 1 11-12-2012 02:13 PM
Need some rear lift info. Atreyus 3rd gen T4Rs 3 04-01-2011 05:31 PM
info on 4runner rear locker tailduster 3rd gen T4Rs 19 10-03-2006 12:30 PM
