Old 01-12-2020, 04:31 PM #1
pinemind pinemind is offline
pinemind will become famous soon enough
1st Gen - Rear Window Key Cylinder Stopped Turning Left (Up)
Hi guys,
A few days ago, I noticed I could no longer turn the key in the rear window lock cylinder to the left to put the window up. Down/right is fine. The interior front console switch works fine in both directions.
I can't recall when it was working, if the cylinder always turns left, and the window won't go up (i.e. when the top is off releasing that bolt switch), or if that switch prevents movement of the lock cylinder completely?
Basically, is this a physical problem or some weird wiring issue? Not sure where to start here.
pinemind is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 02:01 AM #2
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Just mechanical issue with the cylinder.
When working, the tailgate key switch simply connects Pin 11 or 12 of the window control relay to ground to roll up or roll down.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 12:21 PM #3
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Hi guys,
sounds like an issue with the switch itself. you may try some lock cylinder lube, or compressed air. if that doesn't work, you will probably need to replace it.
the last time I checked, they were fairly expensive.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 04:24 PM #4
RAD4Runner's Avatar
RAD4Runner's Avatar
Originally Posted by nevada View Post
...probably need to replace it.
Someone on Yotatech deleted his tailgate roll-up window. I think Cory. Ping him in case he still has the switch.
Old 01-18-2020, 05:56 AM #5
stomper4x4 stomper4x4 is offline
stomper4x4 is on a distinguished road
Yeah mine is the same way. IT still works though if I put the key in then back it out just a hair width, then it works fine. I'm so used to it now I do it quickly and without much jiggling. Mostly I just load up and use the inside switch though.
stomper4x4 is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 12:49 PM #6
All,
Thanks for the suggestions. I used some 3-in-1 dry lock lube and it didn't help. In fact, it made it worse, now I can't turn the key in either direction. Looks like I'll be removing the entire assembly and troubleshooting. I wish this happened before I completely sound deadened my tailgate. This will not be fun in freezing temps .
I did find a detailed write-up on here that I'll use to get at the switch itself:
Tailgate Lock Cylinder Repair (walkthrough)
Also, I have an extra switch but I have no idea of its condition. Luckily the interior switch still works fine.
cylinder , left , lock , switch , window
Rear Window and Wiper stopped working wperk 4th Gen T4Rs 25 09-26-2018 01:08 PM
Rear window stopped working Ry'sRunner Classic T4Rs 10 10-24-2017 01:09 PM
Rear side window stopped working. Need help mattb Classic T4Rs 1 06-08-2011 08:54 PM
Rear window stopped working 88Thunder Classic T4Rs 7 02-15-2010 05:42 PM
'95 Rear window stopped working AznKlique 4th Gen T4Rs 2 03-22-2005 03:38 PM
