Old 05-01-2019, 07:07 PM #1
MBZ300CD's Avatar
MBZ300CD MBZ300CD is offline
Real Name: Gary
MBZ300CD will become famous soon enough
MBZ300CD's Avatar
Real Name: Gary
Gen 1 Transfer Case Output Shaft Leak
My first thread.
I was planning to fix the leak over my transfer case at the output shaft.
When I removed the companion flange it was dry inside the splash(?) cover/guard. When I removed the drive shaft a bunch of gear oil came out of the end. Also there was a bunch of orange RTV on the bolt, washer and spline for the companion shaft. This is before removing the companion flange. So it looks like the seal was good, but why the RTV and why is the oil leaking out of the spline? Is there some part missing? Is it normal?
Additionally the transfer case filler plug head is kind of stripped and doesn't want to come out. Is there any other way to re-fill the transfer case?
Any thoughts on these issues?
help
Thanks
1987 4Runner 22RE 5 spd
Gary
MBZ300CD is offline   Reply With QuoteReply With Quote
Old 05-01-2019, 07:43 PM #2
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
so gonna say the RTV sealant you found was probably a half ass fix by a previous owner. i have had several cases apart over the years and never ran into that.
pull the t/c lever and fill from the top..though it would be best to try to get that stripped fill plug out since you fill it to capacity which is when it starts draining back out the fill hole.
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 05-05-2019, 12:34 PM #3
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
I plan to do that soon.
I think the RTV is part of the re-assembly process.
Please refer to Grego's thread on Yotatech:
Rear oil seal on transfer case - Page 2 - YotaTech Forums
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 05-05-2019, 01:10 PM #4
joeynational's Avatar
joeynational joeynational is offline
joeynational will become famous soon enough
Yes, the RTV is required and normal. So is the oil coming out after you remove the flange.
My build thread;
https://www.toyota-4runner.org/class...achillies.html
joeynational is offline   Reply With QuoteReply With Quote
Old 05-05-2019, 05:52 PM #5
Dropzone's Avatar
Dropzone's Avatar
interesting, i have never seen the RTV on the putput flange and haven't used it when replacing the output seal..have not had a leak back there yet...guess I have been lucky so far
@503dropzone on IG
Old 05-06-2019, 01:57 PM #6
RAD4Runner's Avatar
RAD4Runner's Avatar
Originally Posted by Dropzone View Post
interesting, i have never seen the RTV on the putput flange and haven't used it when replacing the output seal....
So I looked at The Good Book and found out RTV is not required. Perhaps it's just an optional / extra measure that Grego and others did which did not hurt.
Old 05-06-2019, 02:36 PM #7
MBZ300CD's Avatar
Real Name: Gary
MBZ300CD's Avatar
Real Name: Gary
The images from Greg's thread look just like what I found. Thank you for posting the link to it. I had gone to the dealer parts people, but they weren't able to help.
I appreciate everyones attention to my call for help.
Thanks, I can now move forward.
Gary
Old 01-25-2020, 06:36 PM #8
Gone4broke's Avatar
Gone4broke Gone4broke is offline
Gone4broke is on a distinguished road
Gone4broke's Avatar
New user so I can't post my own thread yet and this is the closest I've found on here to my problem.
Front output seal is leaking and I'm just wondering if anyone has any tips on changing it out. there are a ton of write ups for the rear output or for the front for 3rd gens, however, on the first gens that cross member is right in the way of the front output shaft.
Gone4broke is offline   Reply With QuoteReply With Quote
bunch , case , companion , shaft , transfer
Replacing Transfer Case Output Shaft Oil Seals, a How-To for DIY'ers BigFishAllDay 3rd gen T4Rs 82 06-21-2023 09:37 PM
Transfer Case Output Shaft Seal Replacement mtbtim 3rd gen T4Rs 12 06-22-2019 10:14 AM
Transfer Case Output Shaft Leak rwh963 4th Gen T4Rs 4 11-09-2018 11:37 PM
Transfer Case Leak -- Output Shaft Seal Merle Maintenance/Detailing 3 04-17-2017 12:32 PM
HELP! How to-Rear Transfer case output Beari (Tail Shaft Bearing) 4runnertank Classic T4Rs 13 08-10-2012 10:16 PM
