Old 01-27-2020, 08:03 PM #1
Rnc1592 Rnc1592 is offline
Rnc1592 is on a distinguished road
93 wont go over 10 mph?
It also won’t go over any kind of simple hill/bumps in the yard.
YouTube
Torque converter is new. Suggestions on what to check first?
Rnc1592 is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 09:52 AM #2
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Did you just swap the torq converter? Did you pre fill it? Enough fluid in the trans? Does the engine rev all the way up in neutral?
What have you checked already?
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 06:07 PM #3
A buddy wanted my parts truck and I was working a ridiculous amount of hours so I traded the truck for the installation of the torque converter. He definitely has tons of experience and I have faith it was done correctly.
The engine will rev to about 5000, but I didn't attempt to max it out
Old 01-28-2020, 06:36 PM #4
YouTube
This is what is sounded like in June 2019, after I replaced the spark plugs/wires/distributor cap and a new battery. The truck was gifted to me not running.
OH and I also had my buddy pull the transmission out of the donor truck and swap it since he was already down there and had to pull everything out anyways. The reason being is that once I got her running (June of 19, right after I got her) she wouldn't go in reverse at all, just acted like it was in neutral... Maybe this trans is bad too? I honestly haven't checked anything yet, I just flat towed her from his house the other day, with craziness at work I haven't had the time but I do now. The goal is to have her running well by the end of summer, but we will see. That first video she's also running on 3 year old gas, plan to drain and get either a new fuel tank or have the old one hot tanked depending on cost/condition of the old one
ETA: This is also my first vehicle that I've done anything other than drive, so its a learning experience for me lol
Old 01-28-2020, 07:46 PM #5
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
you could always try swapping solenoids
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 07:59 PM #6
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
Any CELs?
I almost want to go around the engine bay with a can of brake cleaner and see if there's any leaks.
I know that's a very long shot in the dark.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 08:10 PM #7
Can you explain further? Or point me in the right direction of some research? I have both a Chiltons and a FSM, if either of those could help me figure it out? Or google search terms? I searched solenoid but its very vague lol (Like I said I'm a super newbie)
Originally Posted by Reinout View Post
Any CELs?
Nope, no CEL. You are talking vacuum leaks yeah?
Old 01-28-2020, 08:35 PM #8
Reinout's Avatar
Real Name: Reinout
Reinout's Avatar
Real Name: Reinout
Yes, Vac leaks. Like I said, it's just a guess and it's probably wrong, but if you have brake cleaner laying around and while the engine runs see if something gets triggered (revs will change).
Edit: It's easier than most other diagnostic methods ☺
Old 01-28-2020, 08:39 PM #9
Yup I do, I will definitely give that a shot! I'm down for some easy and free stuff to try out
Old 01-28-2020, 09:59 PM #10
Any possibility this could be caused by burnt exhaust valves?
Old 01-28-2020, 11:46 PM #11
Just remembered, the only light on the dash that is on is the O/D off light. Idk if that makes a difference or not
Old 01-29-2020, 12:08 AM #12
Sorry to blow this thread up, my brain worked in scattered thoughts :/
So I've been doing some research and I think you've got it. I'm going to replace the lockup and both shift solenoids and see if that fixes the issue.
Old 01-30-2020, 08:22 AM #13
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
So did you check the fluid level?
IG: rattlewagon
check , converter , suggestions , torque , yard
v6 3.4 wont rev above 3k robbie 3rd gen T4Rs 46 09-06-2020 12:15 PM
rear window wont roll down and defrost wont work wanta4runner 3rd gen T4Rs 6 10-17-2016 05:14 AM
please help wont start cfdfire40 3rd gen T4Rs 2 07-05-2013 12:49 PM
Wont go over 500 RPM Mabrouk Classic T4Rs 2 06-25-2012 11:56 PM
92 Four Runner Wont dies and wont start floridaboy6802 Problems & Warranty Issues 0 08-04-2010 10:24 PM
