Old 02-18-2020, 09:22 AM #1
knussear knussear is offline
knussear is on a distinguished road
Reset ECU and now it wont start!
Hi all new to the forum and new to me 1995 4Runner owner. Got a nice truck V6 3.0, Manual Trans. Was running yesterday and had 2 codes when I picked it up 25 and 71. Looking under the hood it had broken wires on the ECU/exhaust Temperature sensor so I replaced the sensor. I Pulled the 20 amp ECU fuse to reset it, and now the vehicle WILL NOT START. Turns over all day, but no fire. Checked all fuses - good, There is power at the fuse box to the ECU, not sure how to check power AT the ecu. Only other thing I did was change the air filter - wondering if I tweaked something on the MAF?. Re-attaching the code jumper yields no check engine light at all, no solid, no blinks, NADA. Any ideas on what else to try? Had the truck 1 day and I broke it. This one is baffling me.
knussear is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 05:27 PM #2
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
It sounds like the ECU is not getting any power. It may be that a tab or blade in the 25 year-old fuse box, or a wire underneath it, broke when you pulled the EFI fuse. Check downstream of that fuse. Pull the EFI main relay and check to see that pins 1 and 5 have 12V during cranking.
Here is a wiring diagram for the engine related stuff.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 09:43 AM #3
Thanks for the reply. I ended up replacing the relay, and then finding that the connectors in the 25 year old fuse box were not connecting tightly enough. I was able to reach in with a small awl and get them to close enough. Off to the next adventure!
Old 02-26-2020, 01:42 PM #4
Following up. I've had intermittent failure on the new relay. Tracked all wires down and I'm now finding that the fuse box in the lower left driver kick panel is the culprit. I get failure once the car has warmed up, and if I move the fuse box pushing forward or rear I can get the car to quit or start. So I would like to get that out of there or at least move it where I can inspect it more closely. I got everything in the way out of there (e.g. cruise control box, door locks box, etc.), and removed the bottom bolt, but I cannot figure out what mechanism will let me loosen the top of the box. Does anyone have any tips about how to get at this?
Old 03-03-2020, 02:40 PM #5
dansoore dansoore is offline
dansoore is on a distinguished road
dansoore is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 12:53 AM #6
Replaced the grey box behind the fuse box called "relay integration" and all is working well now.
Looks like this one.
Old 03-06-2020, 01:28 PM #7
Middlefingergod Middlefingergod is offline
Real Name: Bean
Middlefingergod is on a distinguished road
Real Name: Bean
Glad you got it figured out. I'm having issues with mine and cant get it figured out.
Middlefingergod is offline   Reply With QuoteReply With Quote
check , ecu , fuse , sensor , truck
2000 4runner wont start without clutch start cancle jmcgahran 3rd gen T4Rs 3 08-29-2011 12:27 PM
Moonroof wont reset 4runnerky 4th Gen T4Rs 5 12-05-2010 07:05 PM
92 Four Runner Wont dies and wont start floridaboy6802 Problems & Warranty Issues 0 08-04-2010 10:24 PM
my fuel mile range instrument wont reset 4runnerndachi 4th Gen T4Rs 1 05-03-2006 10:18 AM
Sometimes my auto start wont start my 03..?? BlkSS1755 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 01-10-2004 09:28 AM
