Real Name: Ron
Real Name: Ron
Mine's at 223,000 miles, no issues. Due for a timing belt and probably a valve adjust. Those are the two things I would consider as maintenance beyond the standard fluids, plugs, etc. if I had one without a history.
Mine shows no signs of quitting, and still has normal power, so I don't know how long it might last. I only drive it 5-6K miles per year anymore, so it'll likely outlast my need for it.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
