Old 03-08-2020, 01:49 PM #1
jay333 jay333 is offline
jay333 is on a distinguished road
1990 4Runner Jack Points
I have a 1990 4cyl (22RE) standard transmission 4Runner. I have invested in a proper floor jack and want to make certain I am jacking the vehicle at the best spots. The manual notes the jack points as Front - under the front suspension cross member and Back - under the rear axle housing. However, I can't really jack it up there and then get a jack stand in place at the same spot. Would someone with some knowledge/experience with regards to this advise me where I should be jacking up the front and/or the back of this vehicle with a floor jack so that I can then put the jack stands in place. I have read some say that at the back jack it up on the center of the rear axle housing (right on the differential I assume) - is this proper/safe? I much appreciate recommendations from the experts on this forum. Thank you so much.
jay333 is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 12:05 PM #2
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
(See attached manual page)
The manual shows jack stand locations under the frame in front, just behind the front wheels. You'll need the tall, heavy-duty ("6-ton") kind to have enough length and adequate stability.
In the rear when you jack it up from the center of the diff (the normal jack point), you can then put jack stands under the axle tubes out near the wheels. Again, the manual shows this. You can also put jack stands under the frame in the rear ahead of the rear wheels if you need to have the axle drooping freely, ie. for suspension work.
Do not put jack stands in the front under the lower control arms near the wheels, for two reasons. (1) it stresses the lower ball joints in a way for which they are not designed, and (2), the bottom of the LCA slopes upward toward the center of the vehicle, risking the jack stand slipping out and dropping the vehicle suddenly.
2006 Sport Edition, V8, 193K miles, 2.5/1.5 Daystar spacer lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 223K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 12:43 AM #3
Thank you for the information and diagram - much appreciated!
Old 03-11-2020, 07:20 PM #4
Jimmy Two Dogs's Avatar
Jimmy Two Dogs Jimmy Two Dogs is offline
Jimmy Two Dogs is on a distinguished road
Thanks so much for posting this information!
Jimmy Two Dogs is offline   Reply With QuoteReply With Quote
4runner , back , front , jack , place
Where are the best floor jack points on our 4Runner? sant6236 4th Gen T4Rs 24 03-17-2019 01:00 PM
Seeking advice for Hi-Lift jack points please jjdbike General Discussions 16 11-08-2016 12:26 PM
new to DIY... jack points for front? amalik 3rd gen T4Rs 6 10-03-2013 10:26 AM
high lift jack points on 0'3 alex56 4th Gen T4Rs 4 01-09-2011 09:33 PM
Proper jack points for garage jack? ciaz 5th gen T4Rs 3 02-01-2010 03:14 PM
