I everybody and loved ones are safe.
Originally Posted by Rnc1592
... We tested power at both ends of the 80amp main fuse and everything is getting good power....
A problem well-stated is almost solved. Pls put us AT your truck. Describe everything you see, hear, feel, smell related to the problem.
What is "everything"? If everything is getting good power,then there is no problem.
Battery voltage?
Are you using a multi-meter or test light? I DO NOT TRUST TEST LIGHT.
Where are you connecting your negative multi-meter probe?
Battery connections bare, shiny metal and tight?
Hazards and horn work? Those do not take power from inside the truck.
Did you check everything after the fuse?
What voltage goes into the IGN switch?
What voltage do you get after IGN switch at every position?
