Old 04-24-2020, 10:07 PM #1
Itsme71190 Itsme71190 is offline
Itsme71190 is on a distinguished road
22re rolls backwards while in 1st gear
as title states, plan on getting a tcase brake but I feel like it shouldn't roll. I do need to do a compression test but I feel like there should be enough resistance through the drive train.
Engine
22re bored .075
LC engineering hyper street turbo pistons
Eagle rods
Lc engineering full perimeter crank scraper kit
Arp rod bolts
Arp head studs
OEM toyota seals and head gasket
Cyinderhead
22re
Stock valves
Valve springs and retainers
Stock rockers and shafts
Engnblder 268c crawler cam
Osk oem toyota timing chain and tensioner
Also looking at replacing the tailgate latch cables. Found these, will they work or is there an alternative?
https://www.amazon.com/gp/aw/d/B07ZB..._t1_B00FZJDQ7U
Itsme71190 is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 09:33 AM #2
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
How steep of hill are you on? Does your factory parking brake work?
A compression test would help confirm if the engine is tired. Hows it run otherwise?
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 01:31 PM #3
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
Automatic or Manual transmission? I would think manual by description, so have you checked~verified that the engine is turning over as it rolls backwards??
Is it clutch/transmission/t-case problem?
SaulG is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 11:36 PM #4
jsabowabo jsabowabo is offline
jsabowabo is on a distinguished road
Do a compression test. The truck shouldn't roll backwards in first gear as the engine is being forced through the 4-stroke cycle if that's happening. The other option is the engine is being bypassed by something else, like a slipping clutch.
2004 Tacoma XtraCab TRD 4WD
jsabowabo is offline   Reply With QuoteReply With Quote
22re , arp , engineering , feel , stock
Rolls backwards in D on inclines repo 3rd gen T4Rs 7 01-26-2016 10:43 PM
rear window rolls up and then stops and rolls back down about 1/4 way from top kjhalley New Members 1 04-22-2015 02:11 PM
Rolls backwards in park??? SpeedoJosh 3rd gen T4Rs 9 10-15-2014 10:28 AM
Truck rolls when parked in gear? Gremcat Classic T4Rs 20 04-04-2014 02:39 AM
That's how he rolls. OCMike Classic T4Rs 17 06-09-2012 04:59 PM
