Old 05-07-2020, 01:49 PM #1
WestManCanada WestManCanada is offline
WestManCanada is on a distinguished road
HELP: Coil Spring Mount Rusted Out on 1991 SR5
Hello all
On the 1991 SR5 the top of the rear coil springs mount up in a cylindrical "bracket" attached to the frame. I guess the purpose of these brackets is to keep the coil from shifting sideways under load.
On my vehicle these brackets are rusted out; the descending portion of the left one is essentially gone while the right one is badly corroded. I have attached some photos of the left and right sides.
I have three questions on this:
1) How serious is this? Will is there a danger that the coil spring will "pop out" under normal (ie not extreme off-road) driving conditions?
2) Is the vertical travel of the rear axle sufficiently constrained by shock absorber to prevent the spring from coming out or shifting?
3) Any ideas on how to repair this - can the bracket (which I believe is 501301 / 501302 in the attached diagram) be replaced How is it fastened on (welded, riveted , bolted etc)? Is it even practical to repair?
All comments welcome and appreciated with thanks.
HELP: Coil Spring Mount Rusted Out on 1991 SR5-rear-spring-left-3-jpg  HELP: Coil Spring Mount Rusted Out on 1991 SR5-rear-spring-right-1-jpg  HELP: Coil Spring Mount Rusted Out on 1991 SR5-part-diag-frame-jpg  HELP: Coil Spring Mount Rusted Out on 1991 SR5-part-diag-coil-spring-1-jpg
WestManCanada is offline   Reply With QuoteReply With Quote
Old 02-05-2023, 07:30 PM #2
4GS4RNR 4GS4RNR is offline
4GS4RNR is on a distinguished road
Did you ever figure this out? Diagram is of 96 and up isn’t it?
4GS4RNR is offline   Reply With QuoteReply With Quote
Old 02-21-2023, 07:39 AM #3
4RunnerSafari's Avatar
4RunnerSafari 4RunnerSafari is offline
4RunnerSafari will become famous soon enough 4RunnerSafari will become famous soon enough
I made new ones with new steel bottomplate and a steel ring included a nut for bump stopper and drenage hole on the side.
Not a big job, depends how rusted it is, it is best to fix when axle is out or lowered it down. the prosess to made those is in my build thread.
Sent fra min WAS-LX1 via Tapatalk
4RunnerSafari is offline   Reply With QuoteReply With Quote
Old 02-21-2023, 01:31 PM #4
Edit: i first saw now it was an old thread.. but anyway...
I did like this. sandblasted and painted also before installing the new cups
Old 01-21-2024, 01:40 PM #5
Rooster1313 Rooster1313 is offline
Rooster1313 is on a distinguished road
Is this pretty much back to the original spec? We are working on a 91 and learning as we go. The rear-upper spring perch is pretty much completing gone and need to fab a new one and want to be sure the shape and bump stop position are correct. We initially thought the bump stop went up inside the perch (that's how far it's gone) and mounted through the hole that goes up into the frame. Guessing that's not the case and hoping you can confirm. Thx.
Rooster1313 is offline   Reply With QuoteReply With Quote
attached , coil , left , shifting , spring
Rear Shock Mount Rusted Out Buckaroo 3rd gen T4Rs 21 04-06-2021 01:50 PM
Can't get my Coil Packs off, bolts completely rusted. nalbertasr5 3rd gen T4Rs 11 03-14-2016 11:59 PM
FS: Firestik II antenna with spring, stud mount, and hood mount - $35 Orange County Jeddy For Sale: Non-T4R Items 0 07-02-2014 05:57 PM
FS: 2nd Gen 1991 SR5 Automatic 4WD 3.0 V-6 Silver Spring MD $1000 Scrounger24 For Sale: Vehicles 0 05-06-2014 10:05 AM
Help! Top of Rear Shock Mount Rusted Away seoulstice 3rd gen T4Rs 6 02-23-2013 08:56 PM
