Old 05-11-2020, 11:13 PM #1
ethandaniels ethandaniels is offline
ethandaniels is on a distinguished road
Help! Identify Engine Leak below EGR
Hi All,
I've got a 91' here w/ ~171k miles. Picked it up a couple weekends back, was misfiring all over the place and had some pretty loose steering.
Took it to my mechanic for ~$3k in work...
Brakes (all around), Power Steering reseal (had a leak), Tie Rods, Idle Arm, spark plugs, spark plug wires (old ones were melted to EGR), fuel filter, all fluids.
On a cold start there's a good amount of white smoke blowing out lasting ~15-30seconds. This does smell somewhat sweet so I was very concerned about the Head Gasket. BUT! Around 130k miles the previous owner blew the HG had it replaced and heads resurfaced.
There's some oil leaking right below the EGR Pipe between plug #1 and #3 and looking through some repair manuals I cannot identify where this is coming from. Its a very slow leak (drops 1-2 drips onto concrete / day).
Anyone know where this is leaking from?
Some pictures attached below:
Imgur: The magic of the Internet
ethandaniels is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 12:51 AM #2
Update --
I think its the Valve Cover Gasket that is breaking down and causing the leak.
Old 05-12-2020, 06:53 AM #3
wallytoo's Avatar
wallytoo wallytoo is offline
wallytoo has a spectacular aura about wallytoo has a spectacular aura about
wallytoo's Avatar
just because the head gasket was replaced 40k miles ago doesn’t mean it can’t be failing now. the white smoke and sweet smell should be concerning. testing is in order.
you’ve already spent big bucks, you might be spending more...
member, new hampshire timberland owners association (NHTOA)
1987 4runner sr5, 22re, 5-speed
1988 4runner sr5, 3.0, auto (parts rig)
1987 4runner, sr5, 22re, 5-speed (#2)
wallytoo is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 11:45 PM #4
jsabowabo jsabowabo is offline
jsabowabo is on a distinguished road
White smoke can mean only one thing....Head Gasket. Pull your radiator cap and check for oil in the coolant. Next do a compression test. Just because the HG was replaced does not mean that it was done right. It's possible the cylinder heads needed to be surfaced and were not. Sorry for the bad news, but it's not looking good.
2004 Tacoma XtraCab TRD 4WD
jsabowabo is offline   Reply With QuoteReply With Quote
egr , leak , leaking , plug , steering
oil leak? Pls help identify the plastic piece rainbowheart 5th gen T4Rs 6 03-29-2017 01:14 AM
Help identify possible leak and location LTDSC 4th Gen T4Rs 5 02-01-2016 12:59 AM
Help me identify this leak 4th gen v8 Presta24 Maintenance/Detailing 0 05-21-2015 08:50 PM
Identify The Leak PowrPly 3rd gen T4Rs 7 03-15-2015 11:07 AM
HELP! Can you identify this leak? Theo85 4th Gen T4Rs 18 01-30-2015 09:26 AM
