Old 10-20-2020, 02:09 PM #1
OoerictoO OoerictoO is offline
OoerictoO is on a distinguished road
sunroof drains?
Hey all.
our 88 dlx has been dry its whole life. this past winter it literally filled the 4 footwells with water. i've never seen so much in 4 distinct places in a car before. i thought it was a combination of the sunroof and windshield.
had the windshield removed and re-seated and they fixed up a bunch of the rust under the seal and re-glued it.
but something is still leaking into the front foot wells. my theory is the water wicked itself up from the front wells to the rear.
if this truck has sunroof drains that could be clogged, where do they exit so i can compressed-air them clear?
OoerictoO is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 07:53 PM #2
i see 4 possible drains coming from the top, but i can't for the life of me figure out how to remove the sunroof.
Old 10-20-2020, 08:52 PM #3
okay, so as other posts have pointed out, to get the sunroof off, in "tilt" mode you squeeze the two silver arms together until they clear their pivot pins, then tilt the glass up further and it slides out towards the rear.
the four drains all passed water just fine. i cleared them with compressed air just for good measure. They drain out of the seam weld at the bottom of the body on each side where there are little pinched areas where they are meant to drain, about 5 on each side.
now i guess i'll remove the front cowl and see if the fresh air intake is leaking or something?
Old 10-21-2020, 05:39 PM #4
OzSurf OzSurf is offline
OzSurf will become famous soon enough
Could be the heater core leaking? I was going to suggest sunroof as I had the same issue on my 3rd Gen, though it seems you've thoroughly checked that.
OzSurf is offline   Reply With QuoteReply With Quote
drains , front , sunroof , water , wells
Sunroof leak = Drains clogged. Help pleaee Reh0055 4th Gen T4Rs 15 02-22-2023 08:03 PM
Sunroof drains clogged, sunroof doesn't work. Silicone? thezentree 3rd gen T4Rs 8 06-09-2017 10:31 PM
Where do the sunroof drains exit? bju96 3rd gen T4Rs 30 10-31-2016 08:11 AM
Fixing Leak - roof rack rail leaking, also with pics of rear sunroof drains. [pics] bener 3rd gen T4Rs 2 10-17-2014 02:53 PM
When it rains... it drains... Corrosive 4th Gen T4Rs 9 07-06-2010 03:36 PM
