Hella E-code ECE owners, is the wink/wedge on the left?
So when looking at your vehicle/Hellas from the front is the wink/wedge on the left side?
Not sure if the projected light is a mirror image since it reflects off the back housing reflector and its supposed to be on the Left or Right so that it produces the wedge on the Right side of the road.
Rallylights lists the following part numbers and I know some of them are for kits with bulbs. I want the housing only, I think what I need is the 003427011 but I wanted to make sure I get the right one from elsewhere since I’ve seen it for less, however some of their pics have the wink/wedge on the Left and others on the Right.
003427011
72200
72206
003427811
003427861
I’m going to try LED bulbs for these, HIDs are just way too intense and I think LEDs that mimic the Halo filament placement are the way to go. No need to add relays unlike with a 55/60 or 55/100 halo set-up to get the maximum brightness.
Any suggestions? I’ve seen Beamtech and Sealight on Amz with over 2k and 1k reviews. Leaning on Beamtech with more reviews and lower wattage (less load and probably longer life since the LEDs are not driven as hard). It’s probably be dimmer than higher wattage ones with the same number of LEDs but that’s ok since I don’t want to attract too much attention with super bright and blinding headlights.
Thanks!
