Old 08-18-2020, 08:24 PM #1
sdb999 sdb999 is offline
sdb999 is on a distinguished road
1987 complete brake rebuild
It’s time, pedal to rotors it’s all getting replaced. 1987 22re but I’m buying new anyway so later v6 bits are going in. Looks to me like 91’ v6 parts across the board should bolt on and wok together as intended. Just confirming that 91’ parts will fit.
Thanks.
sdb999 is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 12:08 AM #2
kc15842 kc15842 is offline
Real Name: Kevin
kc15842 will become famous soon enough
Real Name: Kevin
Calipers and rotors are larger. You'll need to slightly add clearance of the dust plate. I would suggest also replacing the hoses with steel braid hoses and don't forget the rear load sensing valve. They tend to corrode and the piston sticks.
I also went with DOT 5.
Good project, its nice knowing it'll stop.
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
kc15842 is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 12:21 PM #3
Thanks for the validation @kc15842 . The load sensing valve will be removed entirely and replaced with a manual biasing valve. Front is well documented, the rear wheel cylinders/drums/hardware will be swapped to 91'/v6 as well which should be some improvement over stock 87'/22re. If you have any experience with the rear swap it would be greatly appreciated. As for stainless lines I'll have to poke around again, my first search didn't bear fruit.
S.
Old 08-21-2020, 12:16 PM #4
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
I think you should also upgrade master cylinder, and possibly the vacuum booster.
I also wonder if those from V6 would plug and play.
Originally Posted by sdb999 View Post
... As for stainless lines I'll have to poke around again..
IIRC, member KEYCW on yotatech just did brake upgrade with SS lines.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 08-21-2020, 03:05 PM #5
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Im running TG braided lines on the 92. They work great.
TOYOTA PICKUP & 4RUNNER EXTENDED BRAKE LINES, 26", DOT APPROVED
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 08-23-2020, 01:16 AM #6
WPG93's Avatar
WPG93 WPG93 is offline
Real Name: Paul
WPG93 is on a distinguished road
WPG93's Avatar
Real Name: Paul
I have an 88, would the kit in that link work for mine?
WPG93 is offline   Reply With QuoteReply With Quote
Old 08-23-2020, 10:54 AM #7
Real Name: Kevin
Real Name: Kevin
Measure your lines. These are extended for folks that have lifted the truck. My guess these are 3-5" longer than stock.
Old 08-23-2020, 01:52 PM #8
WPG93's Avatar
Real Name: Paul
WPG93's Avatar
Real Name: Paul
Ah, good to know! My truck is stocky, which is how I prefer it. My brake lines all need replacing, and at least my front calipers, but I'm pretty new to the brakes game. Should I bother trying to replace them with stock compatible parts, or is it worth looking to installing newer parts like you are since it's going to be an investment anyway? Appreciate your knowledge, and looking forward to hearing about your swap and seeing pictures if you don't mind ��. If it works out well, it'd be nice to see all you did and all you needed to purchase to make it happen!
Old 08-25-2020, 09:49 PM #9
This is good stuff, I’ll look at my lines for length. Yes, when it happens booster and master cylinder will be upgraded as well.
Old 01-06-2022, 02:39 PM #10
Done! All went well and didn't have to cut/flare a single brake line. Complete 91' V6 OEM brakes from firewall to hub. Additional: Removed load sensing valve, new rear wheel bearings/seals, fresh diff fluid and Wilwood prop valve. Stops like it never did before.
S.
Old 01-20-2022, 12:08 PM #11
Only cut/flared one line, at the rear deleting the original load sensing prop valve. So far this is very easy to adjust.
1987 complete brake rebuild-6a-jpg
91’ , board , bolt , it’s , parts
Electrical Upgrade and Rebuild Complete morphious 4th Gen T4Rs 24 08-10-2017 02:09 PM
Complete front suspension rebuild? bubbazr2 4th Gen T4Rs 5 07-27-2015 03:16 PM
1987 4Runner Rebuild/Resto Howitzer Classic T4Rs 2 09-07-2011 09:32 PM
My 84 DD complete rebuild 85toyrunner Gallery 5 09-10-2010 11:22 PM
FS 1987 Complete/No Drivetrain/Rust Free NMRunner Classifieds - buy & sell (no commercial ads please) 0 07-23-2010 12:56 AM
