Old 08-23-2020, 05:21 PM #1
WPG93's Avatar
WPG93 WPG93 is offline
Real Name: Paul
WPG93 is on a distinguished road
WPG93's Avatar
Real Name: Paul
1st gen paint source and advice?
Hello, my truck is looking pretty rough in the paint department after 31 years.
I'm wondering what experience people have had with restoring their paint job at home? What's a good source that's been reliable for paint matching the stock colours?
My paint is 8D8, metallic light blue, here's a link if for some reason you can't find your paint code on your door jam: Toyota 4Runner 1st-Gen Color Code Chart
Do I have to remove all the old paint before I can add new paint? Is it easier to remove the panels and paint them that way? How do you block off areas you don't want to paint?
Any tips or leads on paint sources would be appreciated.
1st gen paint source and advice?-20200823_142232-jpg
WPG93 is offline   Reply With QuoteReply With Quote
Old 08-23-2020, 10:26 PM #2
asimelea asimelea is offline
asimelea is on a distinguished road
Sanding is an important step in a paint job. Getting an exact color match is going to be difficult considering the original paint age and fade. Entire vehicle paint job may turn out better in the end and would also allow you to change colors if you wanted. I'd recommend addressing the fender rust prior to a new paint job. Painters tape and plastic are great ways to cover areas you don't want painted. I'm sure there is better advice on here than I can give. Good luck.
asimelea is offline   Reply With QuoteReply With Quote
Old 08-24-2020, 07:24 PM #3
Melrose 4r's Avatar
Melrose 4r Melrose 4r is offline
Real Name: Thomas
Melrose 4r is on a distinguished road
Melrose 4r's Avatar
Real Name: Thomas
There is a learning curve to doing your own bodywork and paint(two different things). I did mine two summers ago and got great results. I can give some advice and post a link to my build thread where i have photos and details.
Let me try to answer some of your questions but keep in mind, i am not a professional, this is the first time i did a complete vehicle repaint.
The simplest paint job is a repaint in the same color. Each panel depending on what condition it is in may need different prep. If you have a fender that is straight and the old paint is still well-adhered, no you do not have to remove the old paint. Just use wax and grease remover, sand with the appropriate grit, and shoot over it. You do not have to take the hood, doors, fenders off(i did) but you may want to if it’s easier. You will have decisions to make along the way, like to repair rust or just buy a new fender.
I watched many videos on youtube, some over and over to understand the process. And the biggest help was doing business with an auto body supply store where i bought tools, supplies, paint and got lots of advice. Matching the color will be no problem but you will probably have to decide on quality of paint, whether to go with basecoat/clearcoat or single stage.
You’ll need a decent compressor, paint gun for color and clear and a cheap gun for primer. Have another hood, fender or metal panel for testing out filler or paint. It’s really helpful.
Buy quality fillers and paint and it will be easier to get good results. Quality paint in spray cans($$) are more available now and appropriate where needed. If you don’t have the tools, consider doing the bodywork yourself and having a shop spray it. Sometimes classes are available at local tech schools and you get to use their tools and paintbooth, and the guidance of an instructor.
I put a “wow!” Level paint job on my truck myself painting in my yard and garage but buying all the tools and supplies, it still cost me over $2500. Paint is not cheap.
Melrose 4runner 1986 restomod summer beach truck - YotaTech Forums
Melrose 4r is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 02:51 PM #4
Elvet Elvet is offline
Elvet is on a distinguished road
The really frustrating thing is Toyota no longer sells touch up paint that matches many of the early paint codes.
Elvet is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 11:20 PM #5
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Forget Toyota for Paint codes. I went to local body supplies store. They would mix your paint code and package it in Spraymax spray can (Products - SprayMax). Our first-gen MoreFunners do not use a clear topcoat that you see peeling off on 3rd-gents and later. I picked the one-stage one. There is a button you press on bottom, shake and spray. Very nice pattern. It has hardener so you need to use the can within 48-hours once activated. Approx $30 per spray can, but quality and ease of use is well worth it. I do not have a paint booth. I'd find wide open parking where there are no leaves falling and did it quickly
My main cab and touching up the fenders took 3 cans.
My fiberglas cap took another 3 cans.
The shop would also out excess blended paint in pint can without hardener so you can brush on.
1st gen paint source and advice?-20200519_184507-jpg  1st gen paint source and advice?-20200519_153633-jpg  1st gen paint source and advice?-20200515_140549-jpg  1st gen paint source and advice?-20200515_190104-jpg
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 12-19-2020, 05:47 PM #6
Howitzer's Avatar
Howitzer Howitzer is offline
Howitzer is on a distinguished road
Howitzer's Avatar
Hey guys! It's been a few yers since I've been on here last, life has been troublesome, but I am back and look forward to being a part of the group again!
Sams Autobody Supplies in Calgary (noticed your Manitoba location) AB used to mix awesome paint cans or pints of factory colour matched paint, but it appears they have since gone out of business. I have a friend that owns a auto body shop in the countryside near Turner Valley, I will pop by his shop with a beer soon and inquire about paint supply if you'd like. If I find a suitable option in the meantime I will let you know.
87 4Runner Diesel swap in progress- stay tuned for writeup
If Nobody From The Future Comes And Stops You, How Bad Of A Decision Can It Really Be?
Howitzer is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 12:01 PM #7
Ict57 Ict57 is offline
Ict57 is on a distinguished road
Thanks for advice re spray cans.
Ict57 is offline   Reply With QuoteReply With Quote
leads , paint , remove , source , sources
Best source for Attitude Black touch-up paint GreenMountainOwl 5th gen T4Rs 0 04-19-2020 02:17 PM
Need parts source advice mavrick1903 General Discussions 5 06-23-2019 02:31 AM
Paint Advice adkinsadam1 3rd gen T4Rs 9 08-23-2018 09:30 PM
Current source for touch up paint ? Atlanta_man Maintenance/Detailing 5 11-16-2014 07:52 PM
Can anyone point me to a good online source for touchup paint? Y2KSR5 3rd gen T4Rs 1 03-02-2010 05:05 PM
