Old 08-23-2020, 10:56 PM #1
asimelea asimelea is offline
asimelea is on a distinguished road
Requesting torque specs please
Hello I have a 1990 generation 2 4runner 4WD 3.0L standard transmission. I will be replacing the front passenger CV axle and top and bottom ball joints. I'll also be replacing both the pitman arm and idler arm. I haven't been able to locate the torque specs for the related bolts and hoping I could get some assistance here? Can anyone provide the torque specs or point me in the direction to look them up? I don't have a service manual to check them myself. I realize many people just crank down bolts until you can move them anymore, but I feel more comfortable going by the book when I can. Thanks for your help.
asimelea is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 08:28 PM #2
pelantire pelantire is offline
pelantire is on a distinguished road
Lower balljoint to lower suspension arm - 94 ftlbs
from Idler Arm Maintenance
Reinstalling the assembly is very quick. Locate the stud of the idler arm end (the castle nut end) into the steering link, then hold the idler to the frame and start the bolts through. Place the washers and nuts on the bolts and torque to 105 ft. lbs. Push the steering link up towards the idler arm and start the castle nut, and tighten until the hole for the cotter pin is properly centered in one of the cut-outs, which should be around 40 ft. lbs. Jam the cotter pin in, bend the ends around to secure the castle nut, and your idler arm rebuild is complete.
I'm not sure what other bolts you are removing, but I have the maintenance manual so reply if you need more. With bushings in general I tighten until the bushing just starts to bulge.
pelantire is offline   Reply With QuoteReply With Quote
Old 08-26-2020, 11:14 AM #3
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
If you want to go by the book, you should probably get the book.
Even a hayes or chilton manual is a good start and I believe lists the torque specs.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 04:58 PM #4
4RunnerNorway 4RunnerNorway is offline
4RunnerNorway is on a distinguished road
Just replying here to post new thread. Need 15 posts.
4RunnerNorway is offline   Reply With QuoteReply With Quote
arm , bolts , replacing , specs , torque
Torque Specs. Doc2012 3rd gen T4Rs 51 08-21-2023 03:51 PM
Torque Specs JayBluShu 3rd gen T4Rs 9 11-30-2013 09:26 PM
OEM Torque Specs SAC-CA-Runner 3rd gen T4Rs 4 03-11-2013 10:07 PM
Torque specs rocket67 5th gen T4Rs 6 12-13-2012 09:47 PM
Torque specs? Blackdot 3rd gen T4Rs 4 06-21-2011 03:54 PM
